Major Mouse problems, Left click acting like right click, very annoying!
2011-01-08T11:42:31+00:00
Hey guys I have a really annoying problem. I have read about it on-line as other people seem to have experienced it but there is no real definitive answer. On rare occasions, my mouse will act funny. When you press the left button, it will act as the right, and the right button will continue to act as the right one. When you go into the mouse settings, even if you swap them around it still acts like there's two right clicks and no left click buttons. I have tried a number of suggestions from elsewhere on the web including re-booting my pc several times, trying to update windows, disabling the mouse, re-installing, using a different mouse etc.. no matter what I do the problem persists.
The only way to get the mouse back to normal is either to turn the pc off and leave it a few hours, in which case sometimes even that does not work. The only other time it rectifies itself is on its own. Sometimes it will just correct itself without you doing anything to it. I will be very thankful for any advice anyone can give. Has anyone else had this problem? Does anyone know anything at all about it? Thanks BTW My system info: Windows 7 Ultimate 64-Bit, Amd Athlon X2 2.2GHz CPU, 4GB Ram, XFX - MI-A78U-8309 M/B, Few SATA drives, Logitech MK300 Wireless K/Board and Mouse.
2011-01-14T23:20:41+00:00
Hi ;
Can you go to start\control panel\system and security\Administrator Tools\Event Viewer
Please check if you have any error message under the Applications
than publish here or go to our website with this error issue to search
Thanks.
59 additional answers
  1. Deleted
    2012-01-05T06:59:14+00:00
    Fisrt download your touchpad mouse software from manufacture website then You may remove both of them. then restart your computer and install latest touchpad software then restart again.
    2012-01-05T19:07:20+00:00
    Changing antivirus software worked for a day or two and then I got the old mouse problem back.
    The solution that has worked: I bought a new mouse that doesn't use the USB port to communicate with my computer and the problem hasn't shown up again. I miss my old ergonomic mouse (MS Natural Wireless Laser Mouse 7000), but I don't miss the headache.
    2012-06-01T10:49:37+00:00
    I've been searching for solutions too.  This has been happening to me for years and is so frustrating because it seems beyond my control.
    The only thing I find which helps is to run a virus scan and spybot.  I also typically do a ctrl-alt-del to see what's running and then things mysteriously return.
    Even if no threats are reported, this seems to fix things.
