You never want the computer to go to sleep?
Type Power Options into the start search box
Press enter.
Select ChangePlan settings next to the prefered plan that is selected
Set Put the computer to sleep - Never.
original title: mwpetty
How do I stop my computer from going to sleep?
Press enter.
Change Power Settings
How to:
my computer repeatedly sleeps
my laptop repeatedly sleeps
just like an Cherry mobile Blaze(reboots)
I have Windows 10 on my computer. I have had to change the setting related to Sleep over a dozen times at this point. Every time I change it, within 24 hours, the change will reverse itself and Sleep will be set to occur after only one minute of inactivity. How do I fix this so that it stops changing?
