How do I stop my computer from going to sleep?
2011-04-30T15:23:09+00:00
original title: mwpetty
2011-04-30T16:31:09+00:00
You never want the computer to go to sleep?
Type Power Options into the start search box
Press enter.
Select ChangePlan settings next to the prefered plan that is selected
Set Put the computer to sleep - Never.
2011-04-30T16:27:50+00:00
Change Power Settings
How to:
  • Set your computer to go (or not to go) to sleep after a specified period of inactivity. For more information, see Turn off a computer: frequently asked questions.
  • Adjust the brightness of your display.
  • Choose when to turn off the display during periods of inactivity.
  1. Open Power Options by clicking the Start button, clicking Control Panel, clicking System and Security, and then clicking Power Options.
  2. Under the plan that you want to change, click Change plan settings.
  3. On the Change settings for the plan page, choose the display and sleep settings that you want to use when your computer is running on battery (if applicable) and when it's plugged in.
  4. For more options, click “Change advanced power settings.”
  5. When you’re done click OK.
77 additional answers
    2014-05-04T01:56:51+00:00
    2014-10-18T16:59:20+00:00
    I have been unsuccessful with any answers I have seen. I have Windows 8 (which I hate) and when I click on start, I get all the tiles on my desktop and not one for control panel. Neither is there a search box. I used to have control panel on my desk top, which was put there by a support technician as I am clueless when it comes to computers, but I installed Windows 8.1, decided I hated it even more than 8, so I uninstalled it and went back to 8 and everything about my PC has been messed up since.  Any more ideas?
    2014-12-26T12:10:28+00:00
    Get a Mac :-p
    but, seriously, I use a very tiny program when I use windows, it's called "don't sleep"
