A required CD/DVD device driver is missing, usb installation
2011-05-22T12:56:14+00:00
I'm trying to install windows 7 on my freshly built pc by using a usb device (no cd drive as of yet). I followed this guide to do this: http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/.
Whenever I try and boot the device on my new computer I get the "cd/dvd device driver missing..." error and a box for me to select drivers. I have tried changing the boot order in the BIOS but to no avail and I wanted to  change my sata ahci mode  but I couldn't find this option (american microtrends v1.6 bios).
I'd really appreciate it if somebody could help me solve this issue.
2011-05-22T14:58:26+00:00
Ok, I've actually solved this myself via the help of a thread on tom's hardware. I'll post it here for anyone else struggling with the same issue:
OK now is the truth. This is the solution.
I assume all of you is using USB drive to install.
When Windows is asking for driver, just click Cancel. You will be brought back to the welcome screen. At the welcome screen, remove your USB drive, insert it back to DIFFERENT USB PORT. Click Install Now again. The installation process will be like usual.
This problem happened to all new version of updated Windows 7 installer. I think, it is due to failure of Windows installer to remain its detection to the USB drive. It lost the connection, and became confused, don't know where to find the USB drive it used to read before.
When we re-insert the USB drive, Windows installer will detect the USB drive back, and continue like usual.
Good luck and cheers! TQ.
60 additional answers
    2011-06-02T06:41:21+00:00
    That did the trick! :-)
    Thanks a lot for posting your solution TQ.
    2011-07-16T00:41:16+00:00
    Works! Thank you!
    2011-07-21T21:15:18+00:00
    sweet! thank you it works!
    2011-07-23T17:06:54+00:00
    Thank you, thank you, thank you!  Oh did I forget to say THANK YOU!  This is my first PC build.  It's taught me perseverance and faith in staying calm.  What a learning experience.  It's a no go without all that the Internet has to offer!  You caring enough to put good info out there does as much good for the planet as recycling and fostering peace!  Oh and NEVER try to build a PC without another working PC nearby, connected to the Internet.
