Shift + number keys not giving expected symbols
2011-02-13T08:03:49+00:00
At first, I thought my new keyboard was messed up. So I switched from the brand new one back to my old one. And I still have the same problem. Whwn I hold down the SHIFT and 2 key on my keyboard, it suppossed to make the @ sign right
It doesnt.. instead it makes this " (a paranthesis). Same with Shift and 3 keyboard, it makes a slash instead of the usual number sign.
Still, if I wanna make the at sign, I gotta hold down ALT and then key 2... see... @
As for a question mark key... I cant even get that to work. Something is messed up here, and its really annoying. I need my old ways of typing back. Can anyone help me thanks in advance.
Dan
*original title - Just bought a brand new HP computer.. came with Windows 7. My Shift Key wont work...*
2011-02-13T11:10:38+00:00
Sounds as if you have selected an input language other than English. Control Panel, Region and Language; also check to see if your new keyboard has a language selection available that may need to be changed.
<Nintendan> wrote in message news:*** Email address is removed for privacy ***...
Dan
97 additional answers
    2017-10-05T16:41:45+00:00
    Your keyboard has flipped to French language. The Microsoft shortcut to change this is press and hold the Ctrl key and press Shift, or press and hold the left Alt key and press Shift. If one doesn't work the other will
    2017-10-07T17:48:58+00:00
    Thanks that work..I had trouble for 4 days..Thanks again.
    2017-12-08T12:36:21+00:00
    I have exactly the same problem but mine  has occurred after the latest windows update. I have ensured the country codes and settings refer to the united Kingdom. The Ampersand and the Pound Sterling sign are my real concerns.
    2018-02-07T19:48:02+00:00
    THX Man
