Shift + number keys not giving expected symbols
2011-02-13T08:03:49+00:00
At first, I thought my new keyboard was messed up. So I switched from the brand new one back to my old one. And I still have the same problem. Whwn I hold down the SHIFT and 2 key on my keyboard, it suppossed to make the @ sign right
It doesnt.. instead it makes this " (a paranthesis). Same with Shift and 3 keyboard, it makes a slash instead of the usual number sign.
Still, if I wanna make the at sign, I gotta hold down ALT and then key 2... see... @
As for a question mark key... I cant even get that to work. Something is messed up here, and its really annoying. I need my old ways of typing back. Can anyone help me thanks in advance.
Dan
*original title - Just bought a brand new HP computer.. came with Windows 7. My Shift Key wont work...*
2011-02-13T11:10:38+00:00
Sounds as if you have selected an input language other than English. Control Panel, Region and Language; also check to see if your new keyboard has a language selection available that may need to be changed.
<Nintendan> wrote in message news:*** Email address is removed for privacy ***...
Dan
97 additional answers
    2016-06-18T14:32:16+00:00
    Dan
          Check your input method & language under the Control Panel's
    Regional and Language Options.  It sounds like you're using the wrong
    version of English for your location.
    Bruce Chambers
    Help us help you:
    http://support.microsoft.com/kb/555375
    http://www.officeforlawyers.com/howask.htm
    http://www.catb.org/~esr/faqs/smart-questions.html
    They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. ~Benjamin Franklin
    Many people would rather die than think; in fact, most do. ~Bertrand Russell
    only change the input language from united kingdom to US
    2016-10-01T03:16:19+00:00
    I had the exact same problem. None of the combinations suggested like CTRL ALT SHIFT, etc worked.
    Simple solution: on your taskbar, at the bottom right corner of your screen, you can find ENG/US or ENG/UK beside the date and time. Click on it and select your preferred option.
    2016-12-20T02:45:57+00:00
    The solution is quite simple just hold down the shift key and press the ALT key and you should be good to go. I have had this problem many times, the result of fat fingers.
    Ken
    2017-01-06T20:11:48+00:00
    thank you .. it worked.
