Shift + number keys not giving expected symbols
2011-02-13T08:03:49+00:00
At first, I thought my new keyboard was messed up. So I switched from the brand new one back to my old one. And I still have the same problem. Whwn I hold down the SHIFT and 2 key on my keyboard, it suppossed to make the @ sign right
It doesnt.. instead it makes this " (a paranthesis). Same with Shift and 3 keyboard, it makes a slash instead of the usual number sign.
Still, if I wanna make the at sign, I gotta hold down ALT and then key 2... see... @
As for a question mark key... I cant even get that to work. Something is messed up here, and its really annoying. I need my old ways of typing back. Can anyone help me thanks in advance.
Dan
*original title - Just bought a brand new HP computer.. came with Windows 7. My Shift Key wont work...*
2011-02-13T11:10:38+00:00
Sounds as if you have selected an input language other than English. Control Panel, Region and Language; also check to see if your new keyboard has a language selection available that may need to be changed.
<Nintendan> wrote in message news:*** Email address is removed for privacy ***...
Dan
97 additional answers
    2015-05-05T09:22:23+00:00
    Simply
    Press alt + shift
    then
    Press shift + 2
    it will be @
    2015-05-23T17:23:24+00:00
    thanks this helped me out
    2015-07-01T19:25:44+00:00
    I have been trying all the suggestions on here and nothing works for me.
    The strange is that while Ièm (that was suppose to be an approstrophe) this, my shift 2 gives me this:  @ which is correct.  However when Ièm trying to use my email I get an approstrophe.
    My keyboard is really messed up.  Can some one please help meÉ (that was supposed to be a question mark).
    2015-07-01T22:42:31+00:00
    This is the right solution! Worked for me.
