Shift + number keys not giving expected symbols
2011-02-13T08:03:49+00:00
At first, I thought my new keyboard was messed up. So I switched from the brand new one back to my old one. And I still have the same problem. Whwn I hold down the SHIFT and 2 key on my keyboard, it suppossed to make the @ sign right
It doesnt.. instead it makes this " (a paranthesis). Same with Shift and 3 keyboard, it makes a slash instead of the usual number sign.
Still, if I wanna make the at sign, I gotta hold down ALT and then key 2... see... @
As for a question mark key... I cant even get that to work. Something is messed up here, and its really annoying. I need my old ways of typing back. Can anyone help me thanks in advance.
Dan
*original title - Just bought a brand new HP computer.. came with Windows 7. My Shift Key wont work...*
2011-02-13T11:10:38+00:00
Sounds as if you have selected an input language other than English. Control Panel, Region and Language; also check to see if your new keyboard has a language selection available that may need to be changed.
<Nintendan> wrote in message news:*** Email address is removed for privacy ***...
Dan
97 additional answers
    2013-08-03T10:27:00+00:00
    No!!!! It's  simple solution. Press  FN,CTRL and SHIFT at the same time to switch the function of the numbers.
    many thanks fixed my problem
    2013-09-30T09:58:49+00:00
    thx a lot.  work for me :DD
    2013-10-22T09:20:38+00:00
    Press Left Alt + Shift for 4 secs = Problem Fix :)
    2014-02-16T05:47:43+00:00
    DUDE! YOU ARE THE FREAKING MAN!!! THANK YOU! HAHAHA @@@@@@@@@@@@@@@@@@@@@@@ YAY
