Shift + number keys not giving expected symbols
2011-02-13T08:03:49+00:00
At first, I thought my new keyboard was messed up. So I switched from the brand new one back to my old one. And I still have the same problem. Whwn I hold down the SHIFT and 2 key on my keyboard, it suppossed to make the @ sign right
It doesnt.. instead it makes this " (a paranthesis). Same with Shift and 3 keyboard, it makes a slash instead of the usual number sign.
Still, if I wanna make the at sign, I gotta hold down ALT and then key 2... see... @
As for a question mark key... I cant even get that to work. Something is messed up here, and its really annoying. I need my old ways of typing back. Can anyone help me thanks in advance.
Dan
*original title - Just bought a brand new HP computer.. came with Windows 7. My Shift Key wont work...*
2011-02-13T11:10:38+00:00
Sounds as if you have selected an input language other than English. Control Panel, Region and Language; also check to see if your new keyboard has a language selection available that may need to be changed.
<Nintendan> wrote in message news:*** Email address is removed for privacy ***...
Dan
97 additional answers
    2020-01-13T01:11:05+00:00
    This worked for me !
    Thank you so much.  :-)
    2020-01-28T13:05:24+00:00
    2020-02-28T09:10:54+00:00
    when I press Shift+ any key, we are not getting proper out put
    like I press Shift+ tringle key<, out put found pest result.
    2020-02-28T11:33:54+00:00
    look in the lower right hand corner for you keyboard language.
    It needs to be ENG
