Shift + number keys not giving expected symbols
2011-02-13T08:03:49+00:00
At first, I thought my new keyboard was messed up. So I switched from the brand new one back to my old one. And I still have the same problem. Whwn I hold down the SHIFT and 2 key on my keyboard, it suppossed to make the @ sign right
It doesnt.. instead it makes this " (a paranthesis). Same with Shift and 3 keyboard, it makes a slash instead of the usual number sign.
Still, if I wanna make the at sign, I gotta hold down ALT and then key 2... see... @
As for a question mark key... I cant even get that to work. Something is messed up here, and its really annoying. I need my old ways of typing back. Can anyone help me thanks in advance.
Dan
*original title - Just bought a brand new HP computer.. came with Windows 7. My Shift Key wont work...*
2011-02-13T11:10:38+00:00
Sounds as if you have selected an input language other than English. Control Panel, Region and Language; also check to see if your new keyboard has a language selection available that may need to be changed.
<Nintendan> wrote in message news:*** Email address is removed for privacy ***...
Dan
97 additional answers
    2019-10-08T21:44:44+00:00
    2 well not work to a shift a
    Please check your keyboard designation - it should be English United States. It could be UK.   Look in lower right hand corner
    2019-10-09T04:06:31+00:00
    YES, Thank you very much Wesley Phinney.
    2019-10-12T12:11:34+00:00
    I did not like the keyboard that came with my Dell Desktop, so decided to try and use an Anker 7721 that was purchased to use with an iPad. At first I had problems pairing, but sorted that out. Then I noticed (when entering an email address) that Shift 2 which  should have given me @ in fact gave me ". Shift 3 instead of giving me the number symbol (two angled slashes and two horizontal slashes) in fact give me the £ sign. I then discovered that Shift ' gave me @ (opposite of Shift 2) - all other keys appear OK. I have changed language ie. English - American to English UK but that has not solved my problem. Not catastrophic, but would like to get it right. Can anyone help please?
    2019-11-02T23:56:45+00:00
    I want my username take off my QueenGucci#4666 and keep my QueenGucci567 on XBox
    plz
