Shift + number keys not giving expected symbols
2011-02-13T08:03:49+00:00
At first, I thought my new keyboard was messed up. So I switched from the brand new one back to my old one. And I still have the same problem. Whwn I hold down the SHIFT and 2 key on my keyboard, it suppossed to make the @ sign right
It doesnt.. instead it makes this " (a paranthesis). Same with Shift and 3 keyboard, it makes a slash instead of the usual number sign.
Still, if I wanna make the at sign, I gotta hold down ALT and then key 2... see... @
As for a question mark key... I cant even get that to work. Something is messed up here, and its really annoying. I need my old ways of typing back. Can anyone help me thanks in advance.
Dan
*original title - Just bought a brand new HP computer.. came with Windows 7. My Shift Key wont work...*
2011-02-13T11:10:38+00:00
Sounds as if you have selected an input language other than English. Control Panel, Region and Language; also check to see if your new keyboard has a language selection available that may need to be changed.
<Nintendan> wrote in message news:*** Email address is removed for privacy ***...
Dan
97 additional answers
    2019-06-05T20:07:02+00:00
    My shift key still wont give me the "at" sign or question mark
    Check your keyboard language. It may be set to United Kingdom and not the USA.
    2019-07-06T00:48:18+00:00
    Dan
    2019-07-06T11:40:49+00:00
    Hi, please check your keyboard language in the lower right corner of your screen. It shoukd be US keyboard not UK Keyboard.
    2019-09-06T20:53:52+00:00
    Holy crap! That totally worked! Thank you!
