How can you print from Snipping Tool without pasting first?
2011-06-20T17:05:01+00:00
Is there a way to print directly from the Snipping tool whitout having to paste the snip or save it and open in a different program?
2011-06-20T17:45:26+00:00
Click the " ? " on the Snipping Tool for HELP. To print a Snip it has to be put into
Paint or another program. The advantage of using the Snipping Tool is that you
don't have to print the entire screen.
Start - type in Search box -> Snipping Tool    find at top of list and double click on it.
Windows 7 - Features - Snipping Tool
http://windows.microsoft.com/en-US/windows7/products/features/snipping-tool
http://windows.microsoft.com/en-IN/windows7/products/features/snipping-tool
Windows 7 - Snipping Tool
http://www.microsoft.com/windows/windows-7/features/snipping-tool.aspx
Use Snipping Tool to capture screen shots - Vista
http://windows.microsoft.com/en-US/windows-vista/Use-Snipping-Tool-to-capture-screen-shots
Use Snipping Tool to capture screen shots - Windows 7
http://windows.microsoft.com/en-us/windows7/Use-Snipping-Tool-to-capture-screen-shots
Snipping Tool: frequently asked questions
http://windows.microsoft.com/en-us/windows7/Snipping-Tool-frequently-asked-questions
For ALT PrtScr or PrtScr be sure F-Lock key is in the correct position.
How to Take and Create a Screenshot with Windows 7 Paint
http://www.sevenforums.com/tutorials/9717-screenshot-paint.html
Hope this helps.
79 additional answers
    2015-01-13T08:58:49+00:00
    I need the application most on a company PC that is protected against installation of freeware and other software; so the print function is very needed integrated in the snipping tool itself; the work around is indeed very nice but a disgrace for MS they didn't implemented itself
    2015-02-06T15:55:37+00:00
    Same thing here. At work I cant install non-agency software and outlook is not used. At home on my MacBook I use Cmd+Shift+4 it does the same thing but automatically saves the selected area to the desktop as a picture. Open the picture (jpg I think?) and print easy as could be. I don't understand why M$ wont offer something similar? Especially when the software is already there all that needs to be added is a print button.
    2015-02-23T00:20:02+00:00
    Davem1010
      I tried your solution but wanted to create a PDF file.
    Result is a blank out put from a PDF995 Printer
    2015-03-04T18:21:19+00:00
    This is a bug in the snipping tool.  You should just be able to print within the snipping tool - I don't want to save every snip I make.
