How can you print from Snipping Tool without pasting first?
2011-06-20T17:05:01+00:00
Is there a way to print directly from the Snipping tool whitout having to paste the snip or save it and open in a different program?
2011-06-20T17:45:26+00:00
Click the " ? " on the Snipping Tool for HELP. To print a Snip it has to be put into
Paint or another program. The advantage of using the Snipping Tool is that you
don't have to print the entire screen.
Start - type in Search box -> Snipping Tool    find at top of list and double click on it.
Windows 7 - Features - Snipping Tool
http://windows.microsoft.com/en-US/windows7/products/features/snipping-tool
http://windows.microsoft.com/en-IN/windows7/products/features/snipping-tool
Windows 7 - Snipping Tool
http://www.microsoft.com/windows/windows-7/features/snipping-tool.aspx
Use Snipping Tool to capture screen shots - Vista
http://windows.microsoft.com/en-US/windows-vista/Use-Snipping-Tool-to-capture-screen-shots
Use Snipping Tool to capture screen shots - Windows 7
http://windows.microsoft.com/en-us/windows7/Use-Snipping-Tool-to-capture-screen-shots
Snipping Tool: frequently asked questions
http://windows.microsoft.com/en-us/windows7/Snipping-Tool-frequently-asked-questions
For ALT PrtScr or PrtScr be sure F-Lock key is in the correct position.
How to Take and Create a Screenshot with Windows 7 Paint
http://www.sevenforums.com/tutorials/9717-screenshot-paint.html
Hope this helps.
79 additional answers
    2017-11-21T12:09:54+00:00
    Yes there is a menu option in Windows 10 to print from Snipping tool.
    However very disappointing for me - just prints blank pages....
    Peter, I just reconfirmed that my version of Windows10 Pro still prints fine directly from the Snipping Tool. I guess I would confirm that using the CTRL + P option with other MS apps such as WordPad don't produce the same blank page results. Good luck! -- Tim
    2017-11-21T22:05:16+00:00
    I just bought Snagit and like so much better.
    Does anyone know why Office 365 for educators quit including Access?
    2018-01-30T06:21:27+00:00
    I had the same problem but found it does print if I use the "MS Print to PDF" printer option. Doesn't let you control much except paper size though. I'm going to try something that allows more options and better markup tools.
