How can you print from Snipping Tool without pasting first?
2011-06-20T17:05:01+00:00
Is there a way to print directly from the Snipping tool whitout having to paste the snip or save it and open in a different program?
2011-06-20T17:45:26+00:00
Click the " ? " on the Snipping Tool for HELP. To print a Snip it has to be put into
Paint or another program. The advantage of using the Snipping Tool is that you
don't have to print the entire screen.
Start - type in Search box -> Snipping Tool    find at top of list and double click on it.
Windows 7 - Features - Snipping Tool
http://windows.microsoft.com/en-US/windows7/products/features/snipping-tool
http://windows.microsoft.com/en-IN/windows7/products/features/snipping-tool
Windows 7 - Snipping Tool
http://www.microsoft.com/windows/windows-7/features/snipping-tool.aspx
Use Snipping Tool to capture screen shots - Vista
http://windows.microsoft.com/en-US/windows-vista/Use-Snipping-Tool-to-capture-screen-shots
Use Snipping Tool to capture screen shots - Windows 7
http://windows.microsoft.com/en-us/windows7/Use-Snipping-Tool-to-capture-screen-shots
Snipping Tool: frequently asked questions
http://windows.microsoft.com/en-us/windows7/Snipping-Tool-frequently-asked-questions
For ALT PrtScr or PrtScr be sure F-Lock key is in the correct position.
How to Take and Create a Screenshot with Windows 7 Paint
http://www.sevenforums.com/tutorials/9717-screenshot-paint.html
Hope this helps.
79 additional answers
    2016-04-01T01:59:18+00:00
    I gave up!  For so many years I dealt with this issue of back and forth between snip and word.  A wonderful solution is to buy Techsmith's Snagit.. You can print right from the snip and lots more goodies.  Google it.. I love it! peggy
    2016-04-01T02:09:38+00:00
    After snipping a desired portion of some document with the snipping tool, I would like to copy the snip to a WORD document without first saving it to some .jpg file.  When I do this, the WORD file looks correct but when I print the WORD document, the snipped portion is cropped on its right side and thus the entire snipped item is not visible.
    If I save the snipped item first to a .jpg file and then insert it into WORD, everything works fine.  But this is slower and take more keystrokes.
    Can anyone tell me how to copy a snipped item directly to a WORD document?
    Thanks you.
    Frank
    Frank,
    I just used Windows 10 Snipping Tool and captured your whole message, clicked on the Copy icon, pasted into a word document, then printed the doc and it printed fine (albiet a large clipboard image making the insert run slow). There have also been changes to the Snipping Tool in Windows 10 allowing you to print directly using CTRL + P and File, Print as any other program does. What version of Windows are you running?
    Tim Ruffer
    2016-04-01T03:37:19+00:00
    I'm using Windows 7.
    Thanks for your reply.
    Frank_724
    2016-04-01T03:42:21+00:00
    Thank you very much for your reply.
    I kind of thought I was using Snagit but I guess I wasn't.  I don't remember buying it however.  Do you know how much Snagit costs?
    Thanks.
    Frank_724
