How can you print from Snipping Tool without pasting first?
2011-06-20T17:05:01+00:00
Is there a way to print directly from the Snipping tool whitout having to paste the snip or save it and open in a different program?
2011-06-20T17:45:26+00:00
Click the " ? " on the Snipping Tool for HELP. To print a Snip it has to be put into
Paint or another program. The advantage of using the Snipping Tool is that you
don't have to print the entire screen.
Start - type in Search box -> Snipping Tool    find at top of list and double click on it.
Windows 7 - Features - Snipping Tool
http://windows.microsoft.com/en-US/windows7/products/features/snipping-tool
http://windows.microsoft.com/en-IN/windows7/products/features/snipping-tool
Windows 7 - Snipping Tool
http://www.microsoft.com/windows/windows-7/features/snipping-tool.aspx
Use Snipping Tool to capture screen shots - Vista
http://windows.microsoft.com/en-US/windows-vista/Use-Snipping-Tool-to-capture-screen-shots
Use Snipping Tool to capture screen shots - Windows 7
http://windows.microsoft.com/en-us/windows7/Use-Snipping-Tool-to-capture-screen-shots
Snipping Tool: frequently asked questions
http://windows.microsoft.com/en-us/windows7/Snipping-Tool-frequently-asked-questions
For ALT PrtScr or PrtScr be sure F-Lock key is in the correct position.
How to Take and Create a Screenshot with Windows 7 Paint
http://www.sevenforums.com/tutorials/9717-screenshot-paint.html
Hope this helps.
79 additional answers
    2015-08-13T13:31:35+00:00
    Wow!  Great!
    We have to wonder whether this thread had any part at all to play in that decision.   Would be nice to know.
    -- Ken
    2015-11-05T06:20:19+00:00
    I'll stay with Snag-It
    2015-11-05T06:21:25+00:00
    This is the greatest - most useful comment ever.
    2016-04-01T00:59:09+00:00
    After snipping a desired portion of some document with the snipping tool, I would like to copy the snip to a WORD document without first saving it to some .jpg file.  When I do this, the WORD file looks correct but when I print the WORD document, the snipped portion is cropped on its right side and thus the entire snipped item is not visible.
    If I save the snipped item first to a .jpg file and then insert it into WORD, everything works fine.  But this is slower and take more keystrokes.
    Can anyone tell me how to copy a snipped item directly to a WORD document?
    Thanks you.
    Frank
