How can you print from Snipping Tool without pasting first?
2011-06-20T17:05:01+00:00
Is there a way to print directly from the Snipping tool whitout having to paste the snip or save it and open in a different program?
2011-06-20T17:45:26+00:00
Click the " ? " on the Snipping Tool for HELP. To print a Snip it has to be put into
Paint or another program. The advantage of using the Snipping Tool is that you
don't have to print the entire screen.
Start - type in Search box -> Snipping Tool    find at top of list and double click on it.
Windows 7 - Features - Snipping Tool
http://windows.microsoft.com/en-US/windows7/products/features/snipping-tool
http://windows.microsoft.com/en-IN/windows7/products/features/snipping-tool
Windows 7 - Snipping Tool
http://www.microsoft.com/windows/windows-7/features/snipping-tool.aspx
Use Snipping Tool to capture screen shots - Vista
http://windows.microsoft.com/en-US/windows-vista/Use-Snipping-Tool-to-capture-screen-shots
Use Snipping Tool to capture screen shots - Windows 7
http://windows.microsoft.com/en-us/windows7/Use-Snipping-Tool-to-capture-screen-shots
Snipping Tool: frequently asked questions
http://windows.microsoft.com/en-us/windows7/Snipping-Tool-frequently-asked-questions
For ALT PrtScr or PrtScr be sure F-Lock key is in the correct position.
How to Take and Create a Screenshot with Windows 7 Paint
http://www.sevenforums.com/tutorials/9717-screenshot-paint.html
Hope this helps.
79 additional answers
    2015-08-08T17:40:59+00:00
    Dave, Didn't get the jest of your how stupid suggestion. Ken, thanks for mentioning that we cannot add a print tool but must be done via MS.  I don't now if MS ever reads  community comments but I use the clipping tool so many times a day.  I teach online and this is such a good way to visually explain steps whereas words do not.  When I have issues the snip of the error message to IT is more than helpful.  I just wonder if it would be that difficult to add the tool.  peggy
    2015-08-09T06:13:30+00:00
    Because of how you talk to me.. I am out of here.. I did find a great free program on my own that does what I want... thanks for making me feel like and Idiot and stupid..   From how you said what you did.. tells me you are not very smart yourself...   no help or good ideas   so why say anything..  if you cannot say anything good or helpful.. do not say anything.. So yes I hope you take this as good information and shut up and stop talking on here your the idiot not me.. and maybe you get off on trying to say your smart..   go learn English..
    2015-08-09T14:48:53+00:00
    Dave, maybe you haven't been following the whole posting to understand that not everyone has the ability to install new programs on the pc they have access to or the don't have Outlook access to do the email/print/cancel option that someone provided. As others have said, one shouldn't have to download new programs or do multistep processes to utilize print capability. If you don't provide an actual answer to the problem at hand, please don't provide alternatives and then make others that want a proper response feel frustrated that people don't seem to want to listen to the REAL problem. Thank You!
    2015-08-13T01:12:04+00:00
    Well, Microsoft has answered our calls!!!  There is a File -> Print in Windows 10 Snipping Tool.
    Yay!!  No you can get back to your sniping (get it, sniping, snipping :-))
