How can you print from Snipping Tool without pasting first?
2011-06-20T17:05:01+00:00
Is there a way to print directly from the Snipping tool whitout having to paste the snip or save it and open in a different program?
2011-06-20T17:45:26+00:00
Click the " ? " on the Snipping Tool for HELP. To print a Snip it has to be put into
Paint or another program. The advantage of using the Snipping Tool is that you
don't have to print the entire screen.
Start - type in Search box -> Snipping Tool    find at top of list and double click on it.
Windows 7 - Features - Snipping Tool
http://windows.microsoft.com/en-US/windows7/products/features/snipping-tool
http://windows.microsoft.com/en-IN/windows7/products/features/snipping-tool
Windows 7 - Snipping Tool
http://www.microsoft.com/windows/windows-7/features/snipping-tool.aspx
Use Snipping Tool to capture screen shots - Vista
http://windows.microsoft.com/en-US/windows-vista/Use-Snipping-Tool-to-capture-screen-shots
Use Snipping Tool to capture screen shots - Windows 7
http://windows.microsoft.com/en-us/windows7/Use-Snipping-Tool-to-capture-screen-shots
Snipping Tool: frequently asked questions
http://windows.microsoft.com/en-us/windows7/Snipping-Tool-frequently-asked-questions
For ALT PrtScr or PrtScr be sure F-Lock key is in the correct position.
How to Take and Create a Screenshot with Windows 7 Paint
http://www.sevenforums.com/tutorials/9717-screenshot-paint.html
Hope this helps.
79 additional answers
    2011-07-09T18:15:32+00:00
    Sure would make the snipping tool very convenient if you could print directly instead of having to save.
    2011-08-03T17:59:11+00:00
    I've seen this very comment for 2 years, since Vista. Pasting into paint is a time wasting step that could be solved quite easily with a simple print button.
    2012-07-16T23:55:09+00:00
    This is a pain in the derrierre!
    2012-07-20T14:50:18+00:00
    Yes we would like a print option off of the snipping tool!!!!!
