How do I reinstall rtl120.bpl?
2011-05-24T21:44:40+00:00
Original Title: rtl120.bpl?
My computer is telling me that I need to re-install rtl120.bpl. I did not know I had deleted it in the first place and in the second how do I go about re-installing it if I don't have it any more?
Thanks for any help,
Chris
LemP 74,970 Reputation points Volunteer Moderator
2011-05-24T23:02:50+00:00
It would have helped to have the complete error message so I wouldn't have to guess, but rtl120.bpl appears to be related to something called "TuneUp Utilities 2010."  Further, some anti-virus applications apparently were detecting this file as a Trojan horse (and thus deleting it or quarantining it) although those "false positive" detections were from Dec. 2009 and I would have expected the issue to have been long since dealt with.
Assuming that you have something like TuneUp Utilities 2010 installed, I suggest that you uninstall it.  As a general rule, such utilities don't provided much benefit (other than to the income of the vendor) but have the potential for causing problems to your system.  If you can't uninstall whatever it is from Control Panel > Add or Remove Programs, you will probably succeed with free Revo Uninstaller.
67 additional answers
  1. LemP 74,970 Reputation points Volunteer Moderator
    2014-04-11T17:40:26+00:00
    This did not help me. I cannot even find Realtime or Tuneup util. in my programs but keep getting the same disturbing notice :(
    Please help. This is making me crazy
    Thank you
    Did you happen to notice how old the questions and answers were that you responded to?
    And you -- like the person who started this thread 3 years ago -- didn't provide the complete error message.  See the response above from Elder L:
    You might also want to read the "Answer" in this topic:
    http://answers.microsoft.com/en-us/windows/forum/windows_xp-system/download-rtl120bpl/ee869d04-9a07-4ef7-9822-05d484169eb9
    2014-04-12T18:08:39+00:00
    How do I re-install rtl120.btl on my computer? I still haven't received an answer.  VM
    2014-04-12T19:48:32+00:00
    Let's try  this a different way...
    The error message probably says "Re-installing the application may fix this problem."  You do not reinstall the rtl120.bpl application for it is not an application - it is a file.  So you can't reinstall rtl120.bpl.
    You need to reinstall the application that uses the rtl120.bpl file.  Some application you have installed needs the rtl120.bpl file and the file is missing.
    Since the file has nothing to do with XP, it has to do with some third party application that has been installed on your computer.  Since there are probably billions of third party softwares, who know which of those applications use rtl120.bpl.  Hundreds?  Thousands?  Meelions?
    And you are the only one that knows what third party programs you have installed on your computer.
    If the file is missing, it was probably quarantined (effectively deleted) by your unspecified antivirus/antimalware application.  If whatever that is has a quarantine folder, you may be able to restore the file from there.  Otherwise you are going to have to figure out which program you have installed that uses it and reinstall that program
    The rtl120.bpl file is from Embarcadero Technologies and gets installed on your system from third party software packages such as:
    AVG  (their PC Analyzer component)
    TuneUp Utilities
    Advanced System Care  (ASC)
    (others)
    For example, if you have Advanced System Care installed, the message may look like this:
    ASC.exe - Unable to Locate Component
    This application has failed to start because rtl120.bpl was not found.  Re-installing the application may fix this problem.
    From that message, you can see that the complaining program is ASC.exe and that belongs to Advanced System Care, so you would uninstall and reinstall ASC.
    There may be other third party applications that install the file, but if you don't provide the exact error message in it's entirety nobody is going to be able to help you.  And since the file has absolutely nothing to do with Microsoft Windows, maybe nobody in the Microsoft community will be able to help you without more information (like the complete error message).
    You could use msconfig and through a process of elimination perhaps figure it out.
    2014-04-19T21:01:41+00:00
    Another scam.
