How do I reinstall rtl120.bpl?
2011-05-24T21:44:40+00:00
Original Title: rtl120.bpl?
My computer is telling me that I need to re-install rtl120.bpl. I did not know I had deleted it in the first place and in the second how do I go about re-installing it if I don't have it any more?
Thanks for any help,
Chris
LemP 74,970 Reputation points Volunteer Moderator
2011-05-24T23:02:50+00:00
It would have helped to have the complete error message so I wouldn't have to guess, but rtl120.bpl appears to be related to something called "TuneUp Utilities 2010."  Further, some anti-virus applications apparently were detecting this file as a Trojan horse (and thus deleting it or quarantining it) although those "false positive" detections were from Dec. 2009 and I would have expected the issue to have been long since dealt with.
Assuming that you have something like TuneUp Utilities 2010 installed, I suggest that you uninstall it.  As a general rule, such utilities don't provided much benefit (other than to the income of the vendor) but have the potential for causing problems to your system.  If you can't uninstall whatever it is from Control Panel > Add or Remove Programs, you will probably succeed with free Revo Uninstaller.
67 additional answers
    2017-10-12T12:38:06+00:00
    this question was an old one
    2017-10-12T11:43:34+00:00
    Its ok if the vendors name is MS, right?
    NB: Why dont you simply give instructions how to reinstall it without all the political nonsense. Thank you.
    2017-10-12T09:26:34+00:00
