sqlite3-wal-checkpoint can not be located in SQlite3.dll library message appears on startup with windows 7 starter 32bit system.
2011-08-19T11:06:19+00:00
2011-10-03T22:45:58+00:00
Don't worry about it - I fixed it by following the steps below...
Thanks anyway! :-)
  1. Temporarily shut down anti-virus and firewall software
  2. Open Control Panel, Programs and Features (or Add and Remove Programs), and go to the uninstall section
  3. Remove all Apple products in this order - iTunes, Quicktime, Apple Software Update, Apple Mobile Device Support, Bonjour, Apple Application Support.  You do not need to remove Safari
  4. Restart computer
  5. Go to Apple.com and download newest version of iTunes
  6. Re-install
46 additional answers
    2011-10-26T00:38:45+00:00
    Look on the first page of this thread. The second entry describes how to do it on a 64 bit system. If that doesn't work, then try my trick of putting it in whatever the program folder is as well. Good luck!
    2011-10-26T00:43:36+00:00
    Read all of the posts in this thread and try them. There are various issues that cause this error. It was a little hard to understand your reply, but if you only searched in the 'start' folder, you won't find the file. You need to start your search at the root level (i.e. c:\ or d:)
    2011-10-29T14:36:03+00:00
    I've os 7, i tried all the suggested solutionsabove  but j'm having the same problem. I searched in all the itunes, upples etc folders for the sqlite3.dll but nothing in the pc there's not the .dll. My pc is slower at the start up.
    2011-10-29T14:37:06+00:00
    excuse me i've so 64 bit
