sqlite3-wal-checkpoint can not be located in SQlite3.dll library message appears on startup with windows 7 starter 32bit system.
2011-08-19T11:06:19+00:00
2011-10-03T22:45:58+00:00
Don't worry about it - I fixed it by following the steps below...
Thanks anyway! :-)
  1. Temporarily shut down anti-virus and firewall software
  2. Open Control Panel, Programs and Features (or Add and Remove Programs), and go to the uninstall section
  3. Remove all Apple products in this order - iTunes, Quicktime, Apple Software Update, Apple Mobile Device Support, Bonjour, Apple Application Support.  You do not need to remove Safari
  4. Restart computer
  5. Go to Apple.com and download newest version of iTunes
  6. Re-install
46 additional answers
    2014-02-24T02:41:13+00:00
    My computer does the same thing the only difference is that after about 3 seconds my screen goes blank and I cant do anything. I've tried safe mode, safe mode with networking, and starting it from last known good but the only one that seems to not go blank is safe mode with command prompt. Do you have any suggestions that I can use to fix my laptop?
    2014-03-28T13:08:09+00:00
    Esta foi a melhor solução. Obrigado.
    It's the best solution. Thank you.
