sqlite3-wal-checkpoint can not be located in SQlite3.dll library message appears on startup with windows 7 starter 32bit system.
2011-08-19T11:06:19+00:00
2011-10-03T22:45:58+00:00
Don't worry about it - I fixed it by following the steps below...
Thanks anyway! :-)
  1. Temporarily shut down anti-virus and firewall software
  2. Open Control Panel, Programs and Features (or Add and Remove Programs), and go to the uninstall section
  3. Remove all Apple products in this order - iTunes, Quicktime, Apple Software Update, Apple Mobile Device Support, Bonjour, Apple Application Support.  You do not need to remove Safari
  4. Restart computer
  5. Go to Apple.com and download newest version of iTunes
  6. Re-install
46 additional answers
    2013-06-15T12:28:54+00:00
    OK, Thanks...I was not sure it was Apple problem. I signed up in the Apple Community and found a thread that answered my question.
    So for the people with similar problem as mine, please do the following. It cleared that error message right away so this must be the solution.
    1. Go to c:\program files (X86)\Common Files\Apple\Application Support
    2. Find SQlite3.dll in that folder, then right click it and choose Copy
    3. Go to c:\program files(X86)\Common Files\Apple\Mobile Device Support
    4. Paste SQlite3.dll in this folder
    5. Restart your Windows
    ps. use Program Files instead of Program Files(X86) folder if your computer does Not use 64bits. Mine does.
    Hope this help. It helped me.
    That was an excellent solution. In just 3 minutes I fixed the issue. Thanks
    2013-08-17T15:50:27+00:00
     this helped. thnks
    2013-11-08T13:38:39+00:00
    Thanks....this procedure worked perfectly.....now my pc goes to sleep per the settings.
    2014-02-17T08:54:48+00:00
    This is fantastic, saved it to my favourites and it works every time Apple updates iTunes and the problem arises!
