How do I delete huge files from System Volume Information?
2011-08-16T11:37:52+00:00
I have three large hard disks that I use to store backups of the system.  Some program -- I think it was the defragmenter -- caused Win 7 to place huge files (> 4 GB) in System Volume Information.  Nothing I do wil let me delete these files.  I cannot even take ownership of them.  When I try to take ownership of either the file or of System Volume Information I receive an "Access is denied" error on the file name.  Nothing should prevent an administrator from taking ownership of any file on his system.  How can I delete these huge files?  Please do not answer "Use Disk Cleanup to delete all but the last restore point."  That runs, but it deletes nothing.  On a previous installation of Win 7, I could take ownership of System Volume Information and delete its contents, but ot on this new installation.
2011-08-17T10:05:51+00:00
The System Volume information folder keeps the Restore point entries. Usually it is not recommended to delete the entries from the System volume information.
Step 1 : Stop the Volume shadow copy service.
a:  Go to Start - Run and type Services.msc then press enter.
b: Under the Status column look for any entries that read as "Started", make it as “Stopped”.
**c:**Click apply and then ok.
Step 2 : Then take ownership of the System volume Information folder and then try to delete its contents.
How do I open a file if I get an access denied message?
Hope that helps.
47 additional answers
    2014-12-31T02:59:56+00:00
    Thank you, Frederik.
    Since I'm a novice, could you tell me how to start my own thread?
    I think I found a way to get around the problem I mentioned, but I have to run services.msc. When I tried to run, I got the message "The service cannot accept control messages at this time". (Just because I stopped a lot of entries, following Jessen's suggestions, I guess.) I typed "services.msc doesn't run" into our community's search box, but seems this isn't the way to start my own thread.
  2. Deleted
    2014-12-31T15:06:04+00:00
    Thank you very much again. I've already acted accordingly.
  4. Deleted
