How do I delete huge files from System Volume Information?
2011-08-16T11:37:52+00:00
I have three large hard disks that I use to store backups of the system.  Some program -- I think it was the defragmenter -- caused Win 7 to place huge files (> 4 GB) in System Volume Information.  Nothing I do wil let me delete these files.  I cannot even take ownership of them.  When I try to take ownership of either the file or of System Volume Information I receive an "Access is denied" error on the file name.  Nothing should prevent an administrator from taking ownership of any file on his system.  How can I delete these huge files?  Please do not answer "Use Disk Cleanup to delete all but the last restore point."  That runs, but it deletes nothing.  On a previous installation of Win 7, I could take ownership of System Volume Information and delete its contents, but ot on this new installation.
2011-08-17T10:05:51+00:00
The System Volume information folder keeps the Restore point entries. Usually it is not recommended to delete the entries from the System volume information.
Step 1 : Stop the Volume shadow copy service.
a:  Go to Start - Run and type Services.msc then press enter.
b: Under the Status column look for any entries that read as "Started", make it as “Stopped”.
**c:**Click apply and then ok.
Step 2 : Then take ownership of the System volume Information folder and then try to delete its contents.
How do I open a file if I get an access denied message?
Hope that helps.
47 additional answers
    2014-09-07T16:04:34+00:00
    I agree with Gerry.  I had a problem with restore points not being automatically purged on an old Vista system.  It ate up all my disk space and this approach did the trick.  I had to keep doing it periodically as the computer never started to automatically purge restore points but it was not that hard to do.  The computer finally stopped working later that year so that may have been the cause.
    2014-09-07T17:18:32+00:00
    You can manage restore points using cCleaner:
    Paragraph 4.16 here:
    http://www.gerryscomputertips.co.uk/maintenance4a.htm
    2014-12-30T20:37:45+00:00
    Help!
    When I followed Step 1, I could not "make it as 'stopped'", but just stopped it, and I didn't have to "click apply and then OK". That way I think I stopped maybe 20-30 entries. Then I tried to follow Step 2, but found now there was no network connection available. ("The requested nae is valid, but no data of the requested type was found.") Since I didn't make a note of what entry I stopped, now I'm really stuck. Is there any way I can reverse what I did? Thanks in advance for any help.
  4. Deleted
