How do I delete huge files from System Volume Information?
2011-08-16T11:37:52+00:00
I have three large hard disks that I use to store backups of the system.  Some program -- I think it was the defragmenter -- caused Win 7 to place huge files (> 4 GB) in System Volume Information.  Nothing I do wil let me delete these files.  I cannot even take ownership of them.  When I try to take ownership of either the file or of System Volume Information I receive an "Access is denied" error on the file name.  Nothing should prevent an administrator from taking ownership of any file on his system.  How can I delete these huge files?  Please do not answer "Use Disk Cleanup to delete all but the last restore point."  That runs, but it deletes nothing.  On a previous installation of Win 7, I could take ownership of System Volume Information and delete its contents, but ot on this new installation.
2011-08-17T10:05:51+00:00
The System Volume information folder keeps the Restore point entries. Usually it is not recommended to delete the entries from the System volume information.
Step 1 : Stop the Volume shadow copy service.
a:  Go to Start - Run and type Services.msc then press enter.
b: Under the Status column look for any entries that read as "Started", make it as “Stopped”.
**c:**Click apply and then ok.
Step 2 : Then take ownership of the System volume Information folder and then try to delete its contents.
How do I open a file if I get an access denied message?
Hope that helps.
47 additional answers
    2013-09-29T06:33:07+00:00
    Hi Richard,
    Thank you for sharing the resolution with us which will help others facing the same problems to fix it.
    2013-12-09T17:09:38+00:00
    Your suggestion worked perfectly on Windows 7 Enterprise Edition. Cheers for posting the resolution.
    2014-01-02T22:47:48+00:00
    In Windows 8 it's more known as restore points.
    To delete them.
    Win + R
    sysdm.cpl
    Sytem Protection tab
    Under Protection Settings select affected drive i.e (D:)
    Configure
    Change Max Usage: or just click Delete to remove all restore point files.
    Thanks! That helped me too where I had an external USB drive with 93 GB tied up in the SVI folder even though I had the restore points disabled for that drive. I set the slider to zero and deleted the "old" restore points and the files are gone. Thanks again!
    Paul
    2014-01-02T23:23:55+00:00
    Paul
    You should not set System Protection to monitor any drives / partitions other than C"!
