Thank you for your help. Your approach would almost certianly work. I did a similar repair by taking the disk to another Windows 7 installation and deleting the files there, though I had to circumvent security by taking ownership of the files before the
system would let me delete them. However, the best, most principled solution is the following from Windows 7 built-in help:
You can manage the disk space that is used by System Restore by following these steps:
- Click to open System.
- In the left pane, click System protection. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
- Under Protection Settings, click the disk, and then click Configure.
- Under Disk Space Usage, move the slider to the right to increase the disk space that system protection can use or move the slider to the left to decrease the disk space.
I originally set the allowable space to zero, and the system deleted all the files. Later I moved it to 10% (of a 3 TB disk). This is a disk I use solely for backup. There is no need for restore points. When I eventually need the space, I will just
set the allowable space back to zero.
Again, thanks for your help.
Thanks Charles, i rate your answer as the best answer for this particular issue. Because the other suggested methods were either difficult (like using
knoppix live CD which might be a completely new thing to an average user) or did not work at all (like taking control of
System Volume Information (SVI) folder by stopping the Volume Shadow Copy service by running the
services.msc command (in my case it was not running at all!).
I just want to add this to the very effective and native-to-Window solution suggested by you above :-
In case the missing space in the disk is occupied by some huge files inside the SVI folder then while sliding the horizontal bar to minimize disk space allocation for restore points,
**Windows (i'm using Windows 10) will warn that some exisiting restore points will be deleted***which is quite logical and should be expected. One just needs to proceed ahead to free up the missing space.
The missing space issue affects external hard disk as well and Charles' solution works with them as well
By the way, this apparently unexplained missing disk space problem is not limited to internal hard disk of the computer only. In fact, i faced the issue with a 320GB Seagate FreeAgent GoFlex external hard disk. The problem had occurrred after i renamed a
58.5 GB big system image file immediately after creating it with EaseUS Todo Backup app. The name of the big file (almost the size of the system image file of 58.5 GB) residing in the SVI folder consisted of long sequence of digits (and letters?) separated
by hyphens. I presume that was the restore point/file created when i renamed the system image file in the disk FreeAgent GoFlex but i'm not sure. The most surprising thing is that the
System Restore was not even turned on for this disk! (But then who said everthing is easily explained in the world of computing??!!). I just moved the slider to bring down disk space allocation for System Restore for this particular external
disk to 20% from 30% even without turning on the system restore. I just got a warning as said above at *-ed line then i went ahead and the missing space of around 56 GB immediately started showing up!
