error code 80004003
2011-06-14T09:23:17+00:00
I have a HTC mozart phone, when I try to update I get error code 80004003, how do i get rid of this and allow updates?
2011-10-14T20:32:00+00:00
I have now fixed this issue despite "trying everything", by the following:
First, copy any data (pictures and so on) that you may have on your phone to your PC as this will erase everything!
  1. Providing you have copied all your data, reset the phone back to factory settings (Settings > About > Reset your phoe)
  2. Allow the phone to guide you through the "First time use" wizard, but **do not** sign into Windows Live.
  3. "Buy" an app from Marketplace - at this point you are compelled to sign into Windows live but that's fine.
  4. After you have downloaded all the apps you want then you can go to Settings > Email & Accounts > Windows Live and tick the box to sync email (if you want to).
  5. Update your phone using Zune (phone > Settings > Update)
After doing all of that, I found that I was able to get apps, whereas before, any attempt to get any app failed.  The key was NOT to sign into Windows Live when setting up the phone for the first time.
I hope this helps some one else to rectify the issue.
2011-06-19T11:02:26+00:00
Hi Paula2802,
Thank you for your feedback.
Are you trying to update using the Update All button? If so, then try to update each application individually. To do this: Tap the Marketplace tile < Tap Updates < From the App updates list, tap and update each app individually.
If you were already trying this, try to uninstall and then re-install the app again. Follow these steps:
·         Locate the application in the Application List or Games Collection
·         From the Start screen, find the app in your Application List or Games Collection.
·         Tap and hold on the application icon.
·         From the drop-down select uninstall.
·         As soon as the application is uninstalled, go back into Marketplace, locate the application, and choose Install. The newer version of the app will be installed.
**(**If you previously purchased the app, you’ll receive a confirmation when you select buy and the message: “You’ve already purchased this app. Would you like to install it again?” Select Install to reinstall the application. You'll see a similar message for free applications)
Please, keep posting here for further assistance.
Regards,
Nuria S.
2014-01-09T21:40:28+00:00
My problem solved...
guys connect your phone to your pc
zune soft ware start automatically
When your phone connect to your zune soft ware
Open one of you internet browser on your pc
sign in to your windows live id
Go back to your zune soft ware and check for update
If no new update was available start syncing
disconnect your phone from your pc and sign in windows live id from your phone
now you can go to market place and start to download...
i hope this was helpfull...
best regards...
bye
64 additional answers
    2011-10-10T20:48:59+00:00
    I tried the suggestions (while connected via WiFi)  including a factory reset (luckily the phone is new so there weren't too many custom settings to redo).  The reset did not work, so I was very disappointed by that, thinking that if folks in a similar position had loads of settings to redo they'd be none too happy.
    Then I did a restore using the Zune interface with my phone connected to my PC via USB, in order to get rid of a recent WP7 update which Zune had installed for me.
    Shame that while my phone is connected to the USB cable it cannot connect to Marketplace, but oh well, I pulled the cable and tried to update an app, and to buy a new app, neither of which I could do before.
    It failed, and all I got was the dreaded "Can't get this information at the moment. Check again in a little while."
    So if a factory reset and a restore both don't fix the issue, what the heck am I supposed to do?  I have a brand new (24 month contract) phone that cannot buy any apps from the marketplace....  Hmmmm..... not at all happy!!
    2011-10-03T11:11:26+00:00
    I'm also having the same problem and have followed the fix you've given with no success!
    Cookies were already enabled, and having uninstalled the apps that need updating I'm stuck without them because I still can't download them again! This is seriously frustrating!!! :( Will it be fixed in Mango, whenever it finally arrives on my phone?
