My laptop times out too quickly and goes into screen saver mode.
2011-05-15T19:50:33+00:00
How do I change my time -out screen saver control. It seems like one minute and then the screen goes black, then screen saver pictures begin. It's very controling and irritating. Usually if I press a button on the keyboard it will come back, but not always. Please advise.
2011-05-16T13:44:16+00:00
Hi
1.       Was it working fine earlier, if yes then do remember making changes to your computer recently?
Follow these steps to change the settings for screensaver timeout:
a.       Right-click on your desktop and select "Personalize" from the menu that appears.
b.      Click on "Screen Saver" in the Personalization menu.
c.       Use the up and down arrow keys beside the "Wait" box to select the number of minutes you want the computer to wait before it activates the screensaver. You can also type the number of minutes directly into the box.
d.      Click "OK" to finalize your settings.
46 additional answers
    2018-04-05T07:28:26+00:00
    With the PC switched on.
    Sorry, an O/S is active even though the user isn't doing anything... as in - if they are pulling the battery they can't be working on the PC.
    I have to say that the behavior of individual PCs may vary. Certainly a sudden power loss should be handled by Windows such that no operating system damage is done. I was assuming that users would realise the necessity to shut down all programs and save data etc.
    I hope this works for you. It may be specific to HP laptops, even the model I use, and at worst for everyone else, just mine. But I shared the info just in case it works for others.
    25/04/18 Update
    So far every time I have pulled out the battery when logged in (and then put the battery back again) the display timeout has reverted to values I entered in the display settings.
    I'm still not sure what triggers the display to revert to a short timeout. It may be the time of day...
    15/07/18 Update
    I have discovered that normal screen timeout can be restored by removing the battery after putting the PC into sleep mode ie pressing the power button. I am not sure but I suspect that when the OS sleeps there is nothing going on that a loss in power would upset. With the PC alive (active) that always used to be a risk and probably still is. So far using this method has not caused me any problems.
    Pulling the battery recently with the PC alive made it give a blue screen at startup. My recovery memory stick restored normal operation, but clearly pulling the battery has its risks.
    After much investigation it appears there is no correlation between the screen timeout and deleting the user temporary folder contents.
    2018-06-11T16:16:38+00:00
    2018-06-11T16:52:41+00:00
    Can I respectfully suggest that this is not the thread for such a question.
    You would be best to Google your question or try this answer
    This thread is for discussing why the screen times out (to force login again) when the timeout setting that you are asking about are set to Never. So it may be that you will try the above answer and discover that even though the settings are 'never' timeout, it will do anyway.
    I am not sure whether this is a windows 10 problem or something to do with my HP ProBook 450 G2.
    I am continuing to investigate and noticed something the other day. I will report if anything comes from my latest investigation.
    HTH
    2018-06-21T21:24:34+00:00
