My laptop times out too quickly and goes into screen saver mode.
2011-05-15T19:50:33+00:00
How do I change my time -out screen saver control. It seems like one minute and then the screen goes black, then screen saver pictures begin. It's very controling and irritating. Usually if I press a button on the keyboard it will come back, but not always. Please advise.
2011-05-16T13:44:16+00:00
Hi
1.       Was it working fine earlier, if yes then do remember making changes to your computer recently?
Follow these steps to change the settings for screensaver timeout:
a.       Right-click on your desktop and select "Personalize" from the menu that appears.
b.      Click on "Screen Saver" in the Personalization menu.
c.       Use the up and down arrow keys beside the "Wait" box to select the number of minutes you want the computer to wait before it activates the screensaver. You can also type the number of minutes directly into the box.
d.      Click "OK" to finalize your settings.
46 additional answers
    2013-02-06T16:54:51+00:00
    thank you so very very much for your help this will be a big to me             Gabreyll
    2014-05-04T03:35:57+00:00
    My PC times out too quickly and goes into screen saver mode.
    Also how to delete password when starting up
    2014-07-16T06:39:47+00:00
    I did change the screen time out on my laptop, but the screen still goes into sleep mode after only a few minutes. Any other ideas?
    2014-11-10T15:42:02+00:00
    Just set the screensaver to none.
