Defrag Stuck at 1% No Matter How Many Time I Run It
2010-11-10T13:11:29+00:00
Defrag is stuck at one percent even though I have ran it a dozen times completely, this was the case with my system reserve partition too a while ago it was stuck at 14%, now my system reserve partition when it is defraged returns to 0% but my system partition is stuck at 1% no matter how many times I run defrag it seems can that be solved anyhow?
2011-01-21T18:58:19+00:00
Neither the Auslogics or Microsoft Disk Defragmenters defragment the pagefile. If you allow Windows to manage the pagefile and the free disk space is less than 50% of the volume in which the pagefile resides, the pagefile fragments.
The way to avoid this problem is to place the pagefile in it's own partition or to have a fixed minimum = maximum pagefile created before the free disk space reduces below 50%.
This Article tells you how to get round the problem using the Auslogics utility
http://www.auslogics.com/en/articles/how-to-defrag/
Whther the Auslogics solution always works is questionable.  To recreate the pagefile you have to restart the computer. The shutdown causes entries to be written to files so that if there was already limited free disk space these entries start the fragmentation process once again. The new pagefile is created early in the boot process but the files and free disk space have already started to fragment. The Auslogics solution will certainly improve the situation but less so if the free disk space is say only 20% of the drive.
Hope this helps, Gerry Cornell
53 additional answers
    2010-11-11T00:07:38+00:00
    Issue not resolved in my opinion there are probably corrupt files some where causing Windows Defrag to say that there is an amount fragmented even when it is completely defragmented.
    2010-11-11T00:22:17+00:00
    Run the SFC  /SCANNOW  command. This will check and repair if necessary any critical Windows system files.
    Click on Start/All programs/Accessories then
    Right click on Command Prompt option and select 'Run as administrator'.
    At the command prompt enter:  SFC  /SCANNOW
    Windows 7 - SFC SCANNOW Command - System File Checker
    http://www.sevenforums.com/tutorials/1538-sfc-scannow-command-system-file-checker.html
    How to use the System File Checker tool to troubleshoot missing or corrupted system files on Windows Vista or on Windows 7
    http://support.microsoft.com/kb/929833
    How to analyze the log file entries that the Microsoft Windows Resource Checker (SFC.exe) program generates in Windows Vista:
    http://support.microsoft.com/kb/928228
    Open a command Prompt by right clicking and select 'Run as Administrator' and then at the command prompt type:  chkdsk  /f   /r    then press the enter key.
    Also if you know the manufacture of your hard drive you can download their diagnostic software.
    **Hard drive Testing - Bootable CD:**If you have a new Seagate hard drive the very next thing would be to download Seagate's Seatools (the bootable CD) and check for bad sectors:
    http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=SeaTools&vgnextoid=720bd20cacdec010VgnVCM100000dd04090aRCRD
    For Western Digital drives use WdDiag: http://support.wdc.com/product/download.asp?lang=en
    Fujitsu's Utilities: http://www.fujitsu.com/us/services/computing/storage/hdd/support/utilities.html
    Samsung's Estool: http://www.samsung.com/global/business/hdd/support/utilities/ES_Tool.html
    Samsung's Disk manager software: http://www.samsung.com/Products/HardDiskDrive/utilities/shdiag.htm
    Hitachi's Drive Fitness Test software: http://www.hgst.com/hdd/support/download.htm#DFT
    Another utility: SpeedFan has an online health analysis feature
    (SMART tab) for hard drives. It will show how your drives
    compares with other drives of the same make and model.
    http://www.almico.com/speedfan.php
    JS
    http://www.pagestart.com
    Never be afraid to ask. This forum has some of the best people in the world available to help.
    2010-11-11T08:28:48+00:00
    The reports by the Defragmenter provided with Windows are not always helpful. I just checked this computer. The defragmenter provided with Windows reported 0% fragmentation. This was confirmed by Defraggler but there were at the same time 765 fragmented files. Reporting by these tools is misleading because they are selective as to what they report. Another user has told you "the buildin tool skips by default files which are larger than 64MB".
    The user interface of the Defragmenter provided with Windows has long been criticised for providing poor information. The interface was better in XP, and awful in Vista. It is marginally better in Windows 7 compared to Vista and not so good as XP. This is one reason for using a third party defragmenter as better information puts the user more in control rather than having to rely on global assumptions made by those who devised the Windows Defragmenter.
    You will not detect file corruption by reading defragmenter reports. This is better detected by reading Error reports generated by the System.
    2010-11-11T14:07:54+00:00
    No this is lazy technical support, my issue with Windows Defrag has nothing to do with how the defrag works or how complete of a job Windows Defrag does, the only problem is that it sais there is 1% fragmented files even if I run it a dozen times, that is not normal even for Windows Defrag.
    It isn't a problem with how complete my hard drive is defragmented the problem is that Windows Defrag is telling me incorect information about my hard drive fragmentation condition.
