Defrag Stuck at 1% No Matter How Many Time I Run It
2010-11-10T13:11:29+00:00
Defrag is stuck at one percent even though I have ran it a dozen times completely, this was the case with my system reserve partition too a while ago it was stuck at 14%, now my system reserve partition when it is defraged returns to 0% but my system partition is stuck at 1% no matter how many times I run defrag it seems can that be solved anyhow?
2011-01-21T18:58:19+00:00
Neither the Auslogics or Microsoft Disk Defragmenters defragment the pagefile. If you allow Windows to manage the pagefile and the free disk space is less than 50% of the volume in which the pagefile resides, the pagefile fragments.
The way to avoid this problem is to place the pagefile in it's own partition or to have a fixed minimum = maximum pagefile created before the free disk space reduces below 50%.
This Article tells you how to get round the problem using the Auslogics utility
http://www.auslogics.com/en/articles/how-to-defrag/
Whther the Auslogics solution always works is questionable.  To recreate the pagefile you have to restart the computer. The shutdown causes entries to be written to files so that if there was already limited free disk space these entries start the fragmentation process once again. The new pagefile is created early in the boot process but the files and free disk space have already started to fragment. The Auslogics solution will certainly improve the situation but less so if the free disk space is say only 20% of the drive.
Hope this helps, Gerry Cornell
53 additional answers
    2010-11-22T14:44:04+00:00
    What is the status of this problem?
    again, read the link.
    "A programmer is just a tool which converts caffeine into code" CLIP- Stellvertreter http://www.winvistaside.de/
    2010-11-22T16:52:21+00:00
    Neither of those troubleshooting steps worked. No we are not getting anywhere on the other forum thread.
    2010-11-22T18:41:08+00:00
    If you're unable and unwilling to read a simple blog post with the answer, it is your problem.
    2010-11-22T21:00:22+00:00
    I don't know where the link to the blog post is?
