Problem Ejecting USB Mass Storage Device "This device is currently in use. Close any programs or windows that might be using the device, and then try again."
2011-03-23T03:39:03+00:00
Original title:Problem Ejecting USB Mass Storage Device
When I try to safely eject my external hard drive safely I get an error message with this title telling me that "This device is currently in use. Close any programs or windows that might be using the device, and then try again." I have done this. I have also tried closing every program running on the computer and it does not help. I have also tried restarting the computer and this also does nothing. If anyone has any ideas that would be helpful please let me know.
2011-03-24T03:24:11+00:00
Hi A. Cook,
1)       How long have you been facing this issue?
2)       Is this issue confined to any specific USB device?
This behavior can occur if there are open handles with any files in the USB (Universal Serial Bus) Mass Storage Device are in use by another program.
Method 1:
a)       Download Process Explorer from the link below
http://technet.microsoft.com/en-us/sysinternals/bb896653
b)       Click Find, Find Handle or DLL (Dynamic Link Library) in the tool menu.
c)       Type the drive letter of the USB device in the Handle or DLL substring textbox, and press Search Button.
d)       Find the process and its PID (Process Identifier) in the following box.
e)       In system process tree view, find the process according to the Find Handle or DLL dialog box.
f)        Press Ctrl + H to show Handles in Lower Pane View.
g)       Find the File according with the drive letter, and right click it, choose Close Handle.
Reference:
Problem Ejecting USB Mass Storage Devicehttp://support.microsoft.com/kb/555665
Note: Using Third Party Software, including hardware drivers can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the use of Third Party Software can be solved. Using Third Party Software is at your own risk.
**Method 2:**You may refer the steps provided by Diana D in the link below
http://answers.microsoft.com/en-us/windows/forum/windows\_vista-hardware/problem-ejecting-usb-mass-storage-deviceits-in-use/fd56805c-ed8e-491f-8a2b-39ed1c988a71
Method 3: Run an online scan for any threat and try to fix them
**http://onecare.live.com/site/en-Us/center/cleanup.htm**
53 additional answers
    2014-11-15T22:51:56+00:00
    The problem is widely reported.  Thousands of times! It is maddening. It does not matter which USB storage devise is used and it may not be consistent even what the USB device. The point is that some program is using the device and even in task manager you have NO way of knowing which process because nothing in  Task Manager even suggests is it associated with that or any drive. "Only connect" but you can't . Shut down every program running and it will not help. So something in the background is running and GOOD luck trying to sleuth that out.
    The so-called solutions are maddening! The instructions are very badly communicated. The download Process Explorer program suggested? No help.  I get a list of no less than 98 items associated with that drive (which, in this case, is designated as E:) and none of them show up on the task manager. Moreover the instructions on what to do when you find them are incomplete. Not a clue on what to do with those items or how to terminate them. WHO writes this stuff?!  I already have a career!
    So it does not matter what kind of device and the problem will probably not exist every time you use that device. It is not device related but a matter of that device being used by a program and there is no way I can find to connect that device to any program, process, service, etc., that clearly points   to that USB device.
    To terminate whatever is using that device just  reboot the computer. Unless it is a program that loads on boot (which is unlikely) that reboot will terminate whatever item is in operation related to that drive. Then try again and you will be able to eject the device.
    This may be a nuisance but it takes a LOT less time than the hours you will squander going through a bzillion google hits (with as many 'solution' that don't seem to work!) and downloading (possibly malicious) software programs you can't figure out.  Get a Life! You do not need new career. In my case I suspect that whatever Windows process I  used to copy items to the USB device remained in play after the job was done and I could find no way which one was associated with that  drive.  If it's not a program or process that loads on boot it will probably not be active after a reboot.Save the grief. You have WORK to get done. Don't waste more time. Just reboot and then eject.
    2014-11-16T01:47:20+00:00
    Hi JohnM333.
    I fully understand your frustration with this very annoying issue. I think every computer user in the world encounters this problem at some time as it is so widely reported. I have had this same problem with my two previous Windows computers and, due to yet another hard drive failure, (both Dells believe it or not), I had to buy a third new laptop, HP this time, running Windows 8.1, four weeks ago. I bought a WD 1TB external HDD along with it and would you believe that when I connected the HDD to my new computer to try it out I couldn't safely eject it! I thought Microsoft would have sorted the issue out with Windows 8.1 but no that was too much to hope for. I thought to myself, I'll get to the bottom of this for once and for all and so I contacted HP Technical support and asked for their advice on the matter. The technician told me to shut the computer down and "safely eject" the drive by hand! Naturally it worked and the HDD was OK, so I'll be using the shut down method from now on if I can't eject a drive in the normal way. By the way, the reboot method didn't work with my new HP. The problem was still there after restart.
    I hope this will be of help to you and to others as well.
    Best wishes.
    2015-01-18T01:02:29+00:00
    Why can't the OS let you know what app is using the drive, even after all this time? Seriously, even APPLE lets you know what application is using the device. Why can't windows?
    2015-01-18T02:22:17+00:00
    Thanks. I'm seeking answers not more questions I can't answer.  But I did, inadvertently, discover a solution work-around.  Go to Start, then computer, then highlight the device and then right click, choose eject and then choose continue. It's worked every time
