Problem Ejecting USB Mass Storage Device "This device is currently in use. Close any programs or windows that might be using the device, and then try again."
2011-03-23T03:39:03+00:00
Original title:Problem Ejecting USB Mass Storage Device
When I try to safely eject my external hard drive safely I get an error message with this title telling me that "This device is currently in use. Close any programs or windows that might be using the device, and then try again." I have done this. I have also tried closing every program running on the computer and it does not help. I have also tried restarting the computer and this also does nothing. If anyone has any ideas that would be helpful please let me know.
2011-03-24T03:24:11+00:00
Hi A. Cook,
1)       How long have you been facing this issue?
2)       Is this issue confined to any specific USB device?
This behavior can occur if there are open handles with any files in the USB (Universal Serial Bus) Mass Storage Device are in use by another program.
Method 1:
a)       Download Process Explorer from the link below
http://technet.microsoft.com/en-us/sysinternals/bb896653
b)       Click Find, Find Handle or DLL (Dynamic Link Library) in the tool menu.
c)       Type the drive letter of the USB device in the Handle or DLL substring textbox, and press Search Button.
d)       Find the process and its PID (Process Identifier) in the following box.
e)       In system process tree view, find the process according to the Find Handle or DLL dialog box.
f)        Press Ctrl + H to show Handles in Lower Pane View.
g)       Find the File according with the drive letter, and right click it, choose Close Handle.
Reference:
Problem Ejecting USB Mass Storage Devicehttp://support.microsoft.com/kb/555665
Note: Using Third Party Software, including hardware drivers can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the use of Third Party Software can be solved. Using Third Party Software is at your own risk.
**Method 2:**You may refer the steps provided by Diana D in the link below
http://answers.microsoft.com/en-us/windows/forum/windows\_vista-hardware/problem-ejecting-usb-mass-storage-deviceits-in-use/fd56805c-ed8e-491f-8a2b-39ed1c988a71
Method 3: Run an online scan for any threat and try to fix them
**http://onecare.live.com/site/en-Us/center/cleanup.htm**
53 additional answers
    2013-04-13T21:26:30+00:00
    I've had this problem as well, intermittently, and I am running Windows7. I overcome it very simply by putting the computer into 'sleep' mode and then I pull out the USB stick. Works perfectly every time - so far, touch wood!
    2013-04-24T09:12:03+00:00
    i dont know why miscrosoft do not patch for this very easy problems..
    but in Windows 8 everything is fine as far as i know ..
    2013-05-04T15:59:36+00:00
    Download the free **Process Explorer**.
    Run the program.
    Once it's running, click File > Show Details for All Processes.
    Click Find > Find handle or DLL...
    Type the letter for your USB flash drive (e.g. type G: if "G" is your USB drive letter)
    Click Search.
    Look at the results and note the processes. They will tell you what's currently using the drive, so you can terminate it/them.
    Source:http://forums.techguy.org/windows-7/1029584-solved-device-currently-use-message.html
  4. Deleted
