My wireless Optical mouse 2000 Scroll wheel works intermittently-- "the mouse sigal is low"
2011-05-06T21:16:06+00:00
Original Title: My wireless Optical mouse 2000 Scroll wheel works intermittently
I recently purchased a wireless desktop set that has a wireless optical mouse 2000, Wireless Keyboard 100 and a wireless desktop receiver 3.1 in the kit. After installing the drivers and Intellitype/point software the mouse wheel doesn't work all the time, for instance after clicking my way into an eighty plus page PDF manual or long webpage the wheel seems to not work in one direction, then the other direction won't work. I've tried new batteries, latest driver package from microsoft site (intellipoint 8.01) moving closer to the receiver or farther away to the point of "low mouse signal". Today however the mouse is 2-3 feet away from the receiver and it keeps popping up saying "the mouse sigal is low would you like to start the troubleshooter?" Yes i have tried this and tried switching the usb connection to no avail. Can Anyone HELP please.... Tired of Click and Drag
2011-06-07T00:19:00+00:00
The same problem here, but I have found a way to make it work (actually there are two ways LOL)
-   Remove one of the batteries.  Believe it or not, the scroll wheel works perfectly when I remove one of the battery (doesn't matter which one).  However, I don't know how long it will last since there is only one battery in operational.
OR
-  Remove the batter cover and take out the batteries.  Use a screw driver to loose the screw about 2 turns (for some reason I believe it was screwed in too tight).  Put the batteries back and you are or set.
I can not guarantee that my methods will always work, but the fact is it's working for me ever since.
60 additional answers
    2013-07-17T14:30:39+00:00
    2013-07-31T12:41:42+00:00
    I cannot find the screw, taking out one of the batteries only helps for a few seconds here. Where can i find this screw to unlosing?
    Right in the middle between the batteries.
    Loosening the screw and then tightening it just enough to keep the base snug to the top so it doesn't 'clunk' when moving.
    2015-09-05T12:46:11+00:00
    delete microsoft wireless mouse keyboarb program
    2016-01-26T00:48:22+00:00
    Holy cow.. I tried this and it worked. I have been fixing computers for the last 23 years and I did not expect this to work because quite frankly, the wheel seemed to be able to move just fine and without any obstruction. But I thought, what the heck? Why not. Sure enough, it solved the problem for me. The trick was finding the right amount of turns to make because this screw secures to the upper and lower halves of the mouse together. So you need to try maybe a half turn at a time to see what works best for your mouse without making the whole thing to loose..
    Well done Frank
