Cannot create a system restore point and getting error code: 0x81000202.
2010-11-09T14:21:11+00:00
Original Title: cannot create a system restore point
I have Windows 7 Home premium.
I am unable to create a System Restore point.
I go to Control Panel>System & Security>System>System protection
and get the following error message:
There was an unexpected error in the property page.
The volume shadow copy service used by system restore is not working.
For more information view the event log. (0x81000202).
I have also run a sysscan but all is well.
How can I create a system restore point?
Many thanks
David
2013-02-11T01:55:27+00:00
Using Win7, 64bit. Problem solved, solution, fixed  !!
Since I found a solution, I thought I would do a good thing a post it here. Hopefully it will save someone else a bunch of grief. I don't know how universal my case is.
My system is somewhat unique - the original was modified by changing out the C drive for a SSD, which is much smaller than most drives today (120 GB) I put only Windows on that drive, and as much as possible everything else other places.
This means that there isn't a lot of extra room on the C drive for restore point storage.
Creating a restore point would hang with the message that it couldn't get Volume Shadow Service to work After trying everything I could think of and find to try (which took quite a while) I noticed the following:
The current usage for restore points on the C drive was 12.24GB, the maximum (at 10%) was 11.17. Problem, no?
So.. I cut the max to 5%. Windows told me that it would delete old recovery points - which it did. I then raised the limit back to 10% - now there is available space.
Restore point creation worked fine.
Windows should handle this much better. But Windows should handle lots of things better. In any case my problem is solved - I hope this help you out.
In the past, I deleted all restore points to fix the problem, which I didn't want to do this time. But that would have a similar effect of freeing up space. In the future I will be more careful and monitor this occasionally and manually do the same thing - reduce the available space, lose some older restore points, and then reset.
2013-01-11T00:22:28+00:00
If you have any backup software like totalrecovery pro 9 or norton ghost they will prevent you from creating a manual restore point.  I have total recovery pro 9 and all I do is disable the recovery manager when I want to create a manual restore point.  There is no problem with system created restore points they work fine it is the manual ones that are the problem.
Frank
2010-11-25T07:44:45+00:00
David
What other entries are logged on or shortly before or shortly after  that entry i.e. within a minute within a minute either way?
What is interesting is that if the service stopped then it must started which is different to it failed to stop.
Sorry for the delay in answering but  I was busy on other things.
Hope this helps, Gerry Cornell
63 additional answers
    2015-05-12T15:40:28+00:00
    After two years of trying everything, I finally fixed my System Restore using this post by WalterBerndl:  Check if you have a program called "XFast USB" usually installed with the MoBo from the mainboard vendor ASRock.
    When trying to create a restore point, it hung at "creating a restore point," followed by the error message: "The restore point could not be created for the following reasons: The creation of a shadow copy has timed out. Try this operation again. (0x81000101) Please try again."
    I Googled and came across many others who had resolved the 0x81000101 problem by uninstalling XFAST USB. I was experiencing the problem with ASRock Xfast USB version 3.0.28.
    I then uninstalled ASRock Xfast USB (xfastusb) and rebooted. This resolved the 0x81000101 problem.
    NOTE: I first tried to upgrade to ASRock Xfast USB version 3.0.38, but again encountered the error message. Also removing it from the Start Up Menu does nothing, as there is an additional driver it installs to your system. Uninstalling it removes this driver
    Another example of these "booster" programs is ASUS' "USB 3.0 Boost" But if you don't have those kinds of board, but have any kind of "USB turbo-boosters" installed, you still should remove it. They don't get along well with the Volume Shadow Copy service.
