Cannot create a system restore point and getting error code: 0x81000202.
2010-11-09T14:21:11+00:00
Original Title: cannot create a system restore point
I have Windows 7 Home premium.
I am unable to create a System Restore point.
I go to Control Panel>System & Security>System>System protection
and get the following error message:
There was an unexpected error in the property page.
The volume shadow copy service used by system restore is not working.
For more information view the event log. (0x81000202).
I have also run a sysscan but all is well.
How can I create a system restore point?
Many thanks
David
2013-02-11T01:55:27+00:00
Using Win7, 64bit. Problem solved, solution, fixed  !!
Since I found a solution, I thought I would do a good thing a post it here. Hopefully it will save someone else a bunch of grief. I don't know how universal my case is.
My system is somewhat unique - the original was modified by changing out the C drive for a SSD, which is much smaller than most drives today (120 GB) I put only Windows on that drive, and as much as possible everything else other places.
This means that there isn't a lot of extra room on the C drive for restore point storage.
Creating a restore point would hang with the message that it couldn't get Volume Shadow Service to work After trying everything I could think of and find to try (which took quite a while) I noticed the following:
The current usage for restore points on the C drive was 12.24GB, the maximum (at 10%) was 11.17. Problem, no?
So.. I cut the max to 5%. Windows told me that it would delete old recovery points - which it did. I then raised the limit back to 10% - now there is available space.
Restore point creation worked fine.
Windows should handle this much better. But Windows should handle lots of things better. In any case my problem is solved - I hope this help you out.
In the past, I deleted all restore points to fix the problem, which I didn't want to do this time. But that would have a similar effect of freeing up space. In the future I will be more careful and monitor this occasionally and manually do the same thing - reduce the available space, lose some older restore points, and then reset.
2013-01-11T00:22:28+00:00
If you have any backup software like totalrecovery pro 9 or norton ghost they will prevent you from creating a manual restore point.  I have total recovery pro 9 and all I do is disable the recovery manager when I want to create a manual restore point.  There is no problem with system created restore points they work fine it is the manual ones that are the problem.
Frank
2010-11-25T07:44:45+00:00
David
What other entries are logged on or shortly before or shortly after  that entry i.e. within a minute within a minute either way?
What is interesting is that if the service stopped then it must started which is different to it failed to stop.
Sorry for the delay in answering but  I was busy on other things.
Hope this helps, Gerry Cornell
63 additional answers
    2010-12-25T07:20:54+00:00
    Also, every time I click the System Protection tab I get a pop-up Error Box that reads:
      There was an unexpected error in the property page:
       The Volume Shadow Copy service used by System Restore is not working.  For more information view the event log.
        (0x81000202)
    Iin addition, when I run Services.exe I don't even have Volume Shadow Copy in the list!
    You need to look for "Microsoft Software Shadow Copy Provider".
    Select Start, Control Panel, Administrative Tools, Services. Scroll down the list of Services and place the cursor on "Microsoft Software Shadow Copy Provider". Right click and select Properties. On the General tab  change the StartUp type to Manual and click on Apply and OK. Exit and restart your computer. Test by trying to create a Restore Point. If this is unsuccessful come back here was further assistance.
    For others reading this thread the above was the final step in a long diagnostic process leading from the original error code 0x81000202 to resolving a problem where the user was unable to manually create a restore point. If the simple change described in the paragraph above fails to produce the desired result I recommend that the StartUp type of all interdependent services involved in the creation of restore points be checked and returned to the default.
    2010-12-25T07:35:14+00:00
    Khairun
    Thank you for reporting your success.
    I have added a note to the thread summarising the solution to resolve this particular problem. It was apparent from the post before your own that not everyone was able to see what they needed to do. The thread is difficult to read and I hope I have made the solution clearer.
    Regards, Gerry Cornell
