Cannot create a system restore point and getting error code: 0x81000202.
2010-11-09T14:21:11+00:00
Original Title: cannot create a system restore point
I have Windows 7 Home premium.
I am unable to create a System Restore point.
I go to Control Panel>System & Security>System>System protection
and get the following error message:
There was an unexpected error in the property page.
The volume shadow copy service used by system restore is not working.
For more information view the event log. (0x81000202).
I have also run a sysscan but all is well.
How can I create a system restore point?
Many thanks
David
2013-02-11T01:55:27+00:00
Using Win7, 64bit. Problem solved, solution, fixed  !!
Since I found a solution, I thought I would do a good thing a post it here. Hopefully it will save someone else a bunch of grief. I don't know how universal my case is.
My system is somewhat unique - the original was modified by changing out the C drive for a SSD, which is much smaller than most drives today (120 GB) I put only Windows on that drive, and as much as possible everything else other places.
This means that there isn't a lot of extra room on the C drive for restore point storage.
Creating a restore point would hang with the message that it couldn't get Volume Shadow Service to work After trying everything I could think of and find to try (which took quite a while) I noticed the following:
The current usage for restore points on the C drive was 12.24GB, the maximum (at 10%) was 11.17. Problem, no?
So.. I cut the max to 5%. Windows told me that it would delete old recovery points - which it did. I then raised the limit back to 10% - now there is available space.
Restore point creation worked fine.
Windows should handle this much better. But Windows should handle lots of things better. In any case my problem is solved - I hope this help you out.
In the past, I deleted all restore points to fix the problem, which I didn't want to do this time. But that would have a similar effect of freeing up space. In the future I will be more careful and monitor this occasionally and manually do the same thing - reduce the available space, lose some older restore points, and then reset.
2013-01-11T00:22:28+00:00
If you have any backup software like totalrecovery pro 9 or norton ghost they will prevent you from creating a manual restore point.  I have total recovery pro 9 and all I do is disable the recovery manager when I want to create a manual restore point.  There is no problem with system created restore points they work fine it is the manual ones that are the problem.
Frank
2010-11-25T07:44:45+00:00
David
What other entries are logged on or shortly before or shortly after  that entry i.e. within a minute within a minute either way?
What is interesting is that if the service stopped then it must started which is different to it failed to stop.
Sorry for the delay in answering but  I was busy on other things.
Hope this helps, Gerry Cornell
63 additional answers
    2010-11-10T01:46:45+00:00
    Maybe check this link
    http://social.answers.microsoft.com/Forums/en-US/w7repair/thread/9689139d-a115-405d-9f63-b0151b72a52c
    vader95 Windows 95-7 office 97-2010 Ubuntu 9.10-10.10
    2010-11-10T17:56:18+00:00
    Hi drc1939,
    ·        Do you remember making any changes to the computer after which the issue started?
    ·        Which antivirus software is installed on the computer?
    Try the following steps and check if it helps:
    Step 1:
    Make sure that Volume Shadow Copy service is started.
    a. Click Start, type “services.msc” (without quotes) and press Enter.
    b. Locate and right-click "Volume Shadow Copy" service, and then click Start.
    Step 2:
    Temporarily disable the antivirus software running on the computer and then try creating restore point and check if it helps.
    **Disable antivirus software**
    ***Warning:***Antivirus software can help protect your computer against viruses and other security threats. In most cases, you shouldn't disable your antivirus software. If you have to temporarily disable it to install other software, you should re-enable it as soon as you're done. If you're connected to the Internet or a network while your antivirus software is disabled, your computer is vulnerable to attacks.
    Hope this helps.
    Thanks and Regards, Santosh Y – Microsoft Support
    Visit our **Microsoft Answers Feedback**Forum and let us know what you think.
