Specified Module could not be found (LogiLDA.dll)
2011-02-17T19:28:37+00:00
I made the mistake of running a registry cleaner and now get a computer startup error that states that the following ddl cannot run. As far as I can tell it is a Ligitech<br> Download Manager file. Do you know what I can do to fix this? <br><br> <br><br>C:\Windows\System32\LogiLDA.dll
2012-02-03T23:36:49+00:00
I had it too. This is what I did to fix it.
I went to Control Panel>System>Device Manager>Human Interface Devices>USB input Device (Logitech Download Assistant). Doube click. Uninstall driver.
Then Action>Scan for hardware changes and the driver updates itself from MS with Logitech ware.
"logiLDA.dll" error is GONE.
I personally like a clean registry, although I know tech fundamentalists don't. So I will stick with it, but will keep an open mind.
If it comes back I will repost, as the idea of a "restore" is a good suggestion.
Jonathan AU
2011-02-17T21:26:24+00:00
On Thu, 17 Feb 2011 19:28:37 +0000, DBC 7500 wrote:
I made the mistake of running a registry cleaner and now get a computer startup error that states that the following ddl cannot run. As far as I can tell it is a Ligitech Download Manager file. Do you know what I can do to fix this?
Do a system restore to a date before you used the registry cleaner.
And in the future, avoid using registry cleaners. Registry cleaning
programs are all snake oil. Cleaning of the registry isn't needed
and is dangerous. Leave the registry alone and don't use any registry
cleaner. Despite what many people think, and what vendors of registry
cleaning software try to convince you of, having unused registry
entries doesn't really hurt you.
The risk of a serious problem caused by a registry cleaner erroneously
removing an entry you need is far greater than any potential benefit
it may have.
Read http://www.edbott.com/weblog/archives/000643.html
and http://aumha.net/viewtopic.php?t=28099
and also
http://blogs.technet.com/markrussinovich/archive/2005/10/02/registry-junk-a-windows-fact-of-life.aspx
Let me point out that neither I nor anyone else who warns against the
use of registry cleaners has ever said that they always cause
problems. If they always caused problems, they would disappear from
the market almost immediately. Many people have used a registry
cleaner and never had a problem with it.
Rather, the problem with a registry cleaner is that it carries with it
the substantial risk of having a problem. And since there is no
benefit to using a registry cleaner, running that risk is a very bad
bargain.
Ken Blake (MS MVP)
89 additional answers
    2013-11-01T18:14:25+00:00
    I upgraded to Windows 8.1 and could not find evidence of a Logitech updater. If any one has a specific solution for the 8.1 caused problem please let us know.  Also we do not have a restore point prior to the 8.1 update so that is not an option. Thanks.
    UPDATE:  I went to the task manager and disabled it under the start up tab.  This fixed the problem
    2013-11-04T02:28:44+00:00
    Yes, it has happened to me as well and Microsoft is doing nothing about it to help fix this! It's very frustrating!
    2013-11-04T15:00:32+00:00
    Thank you for posting a short and succinct solution to the problem without getting into related but irrelevant debates :-) I had the DLL error pop up after an otherwise butter smooth update of my company laptop to Windows 8.1.
    I figured it was a Logitech thing as I have seen similar issues (though different error messages) when I have upgraded my MacBook Pro in the past. I did follow your tip and see USB entries but alas not one with Logitech's name in front of it.
    Will try to find another way, maybe removing any Logitech control panel that may have been previously installed.
    Regards
    Imran
    http://twitter.com/imrananwar
    I had the same message with no Logitech software installed, so I searched the registry for this file and found it under Run.  I deleted the value and this went away.  Another way to do the same thing might be to run MSConfig (or Advanced Mode on the new Task Manager) and pull it out that way.
