Specified Module could not be found (LogiLDA.dll)
2011-02-17T19:28:37+00:00
I made the mistake of running a registry cleaner and now get a computer startup error that states that the following ddl cannot run. As far as I can tell it is a Ligitech<br> Download Manager file. Do you know what I can do to fix this? <br><br> <br><br>C:\Windows\System32\LogiLDA.dll
2012-02-03T23:36:49+00:00
I had it too. This is what I did to fix it.
I went to Control Panel>System>Device Manager>Human Interface Devices>USB input Device (Logitech Download Assistant). Doube click. Uninstall driver.
Then Action>Scan for hardware changes and the driver updates itself from MS with Logitech ware.
"logiLDA.dll" error is GONE.
I personally like a clean registry, although I know tech fundamentalists don't. So I will stick with it, but will keep an open mind.
If it comes back I will repost, as the idea of a "restore" is a good suggestion.
Jonathan AU
2011-02-17T21:26:24+00:00
On Thu, 17 Feb 2011 19:28:37 +0000, DBC 7500 wrote:
I made the mistake of running a registry cleaner and now get a computer startup error that states that the following ddl cannot run. As far as I can tell it is a Ligitech Download Manager file. Do you know what I can do to fix this?
Do a system restore to a date before you used the registry cleaner.
And in the future, avoid using registry cleaners. Registry cleaning
programs are all snake oil. Cleaning of the registry isn't needed
and is dangerous. Leave the registry alone and don't use any registry
cleaner. Despite what many people think, and what vendors of registry
cleaning software try to convince you of, having unused registry
entries doesn't really hurt you.
The risk of a serious problem caused by a registry cleaner erroneously
removing an entry you need is far greater than any potential benefit
it may have.
Read http://www.edbott.com/weblog/archives/000643.html
and http://aumha.net/viewtopic.php?t=28099
and also
http://blogs.technet.com/markrussinovich/archive/2005/10/02/registry-junk-a-windows-fact-of-life.aspx
Let me point out that neither I nor anyone else who warns against the
use of registry cleaners has ever said that they always cause
problems. If they always caused problems, they would disappear from
the market almost immediately. Many people have used a registry
cleaner and never had a problem with it.
Rather, the problem with a registry cleaner is that it carries with it
the substantial risk of having a problem. And since there is no
benefit to using a registry cleaner, running that risk is a very bad
bargain.
Ken Blake (MS MVP)
89 additional answers
    2017-06-21T17:24:54+00:00
    Microsoft updated my windows 10  to version 1703 and since then i receive the message ''cannot find logiLDAII procedure '' when starting my PC
    2017-08-09T11:29:25+00:00
    i have a probelem  a window starting
    2017-08-09T11:30:46+00:00
    problem window starting
