Specified Module could not be found (LogiLDA.dll)
2011-02-17T19:28:37+00:00
I made the mistake of running a registry cleaner and now get a computer startup error that states that the following ddl cannot run. As far as I can tell it is a Ligitech<br> Download Manager file. Do you know what I can do to fix this? <br><br> <br><br>C:\Windows\System32\LogiLDA.dll
2012-02-03T23:36:49+00:00
I had it too. This is what I did to fix it.
I went to Control Panel>System>Device Manager>Human Interface Devices>USB input Device (Logitech Download Assistant). Doube click. Uninstall driver.
Then Action>Scan for hardware changes and the driver updates itself from MS with Logitech ware.
"logiLDA.dll" error is GONE.
I personally like a clean registry, although I know tech fundamentalists don't. So I will stick with it, but will keep an open mind.
If it comes back I will repost, as the idea of a "restore" is a good suggestion.
Jonathan AU
2011-02-17T21:26:24+00:00
On Thu, 17 Feb 2011 19:28:37 +0000, DBC 7500 wrote:
I made the mistake of running a registry cleaner and now get a computer startup error that states that the following ddl cannot run. As far as I can tell it is a Ligitech Download Manager file. Do you know what I can do to fix this?
Do a system restore to a date before you used the registry cleaner.
And in the future, avoid using registry cleaners. Registry cleaning
programs are all snake oil. Cleaning of the registry isn't needed
and is dangerous. Leave the registry alone and don't use any registry
cleaner. Despite what many people think, and what vendors of registry
cleaning software try to convince you of, having unused registry
entries doesn't really hurt you.
The risk of a serious problem caused by a registry cleaner erroneously
removing an entry you need is far greater than any potential benefit
it may have.
Read http://www.edbott.com/weblog/archives/000643.html
and http://aumha.net/viewtopic.php?t=28099
and also
http://blogs.technet.com/markrussinovich/archive/2005/10/02/registry-junk-a-windows-fact-of-life.aspx
Let me point out that neither I nor anyone else who warns against the
use of registry cleaners has ever said that they always cause
problems. If they always caused problems, they would disappear from
the market almost immediately. Many people have used a registry
cleaner and never had a problem with it.
Rather, the problem with a registry cleaner is that it carries with it
the substantial risk of having a problem. And since there is no
benefit to using a registry cleaner, running that risk is a very bad
bargain.
Ken Blake (MS MVP)
89 additional answers
    2011-02-18T16:08:20+00:00
    On Fri, 18 Feb 2011 15:05:31 +0000, DBC 7500 wrote:
    Thanks Ken,
    I had never used a registry cleaner before but I was having another issue that every google search recommnended to clean the registry.
    Lesson learned! I couldn't do a restore for this last issue because while having another problem (windows explorer has quite working, windows explore is restarting...over and over) I upgraded from Win7 Home Premium to Windows Ultimate because I had read that this would rebuild windows and solve the issue without losing ones files. It didn't work either but I was abale to solve that issue.
    I did seek help from Logitech (that dll is thier file by the way) and they said to uninstall the set point drivers and reinstall. This did not help. What finally did work late yesterday was to access msconfig and unchecked it under the Startup tab. Hopefully that will suffice. Everything seems to be back in order.
    What I have learner is 'don't use a registry cleaner as it will likely cause more problems that it is worth'. I did get a refund, but that sure didn't cover the cost of the hours spend cleaning up after them.
    Thanks for taking time to respond to my post.
    You're welcome. Glad to help.
    Ken Blake (MS MVP)
    2011-02-18T15:05:31+00:00
    Thanks Ken,
    I had never used a registry cleaner before but I was having another issue that every google search recommnended to clean the registry. Lesson learned! I couldn't do a restore for this last issue because while having another problem (windows explorer has quite working, windows explore is restarting...over and over) I upgraded from Win7 Home Premium to Windows Ultimate because I had read that this would rebuild windows and solve the issue without losing ones files. It didn't work either but I was abale to solve that issue.
