How to sort by most recent with folders on top?
2011-01-12T06:03:24+00:00
Is there a way to sort files by date (reverse, current items first) but keep the folders on top of the directory structure? If so, how? I used to have this setting and it disappeared.
To be clearer, I'm looking for something like this
[folder] abc
[folder] def
[folder] ghi
[file] whatever - modified 1/11/11
[file] filename doesn't matter - modified 1/10/11
[file] you get the idea - modified 1/4/11
[file] and it was 2010 - modified 12/29/10
Does this make sense? Again, I had this setting before and it disappeared. What happened to it, and how do I get it back? A reboot didn't fix it for me. I tried to right click "Sort By" and don't see this option. ALL I want are the folders on top... I don't care about the folder names.
Thanks!
2011-02-11T15:04:54+00:00
I don't know if this is still an issue for the original poster, or if he's gone back to WinXP :)
But recently I was having this annoyance myself.
I wanted to display the contents of a folder (not a library) in detail or list mode, with the most recent on top. However, the default behaviour is to have the folders at the bottom - NOT what I want.
After a LOT of fiddling, I realised that this only happens when the "Date Modified" field is used for sorting. I have found that by using the "Date" sorting field, the folders appear at the top as they (imo) should be.
So, to recap:
  1. Go to a regular folder (NOT a library)
  2. Right-click the field header area
  3. If present, put a tick next to "Date"
  4. If 'Date' isn't there, click 'More' and find it there.
  5. Move the new Date field into position, and click it to sort on date.
Hope that helps :)
2011-06-03T06:51:09+00:00
otaru's fix did the trick instantly for me.  I had messed around with that concept, but for some reason I only tried ctrl + click on name and alt + click on name.  Never tried shift + click on name for some reason, and instead got all frustrated by this until now.  But, all is well again!  Thanks.
2011-04-01T20:40:23+00:00
Guys the solution for this problem is on the first page , you have to view the folder files by Detail to see each way you can sort.
Then you click on Date Modified , then Shift + Click on Name , it will fix the sort to always put folders first.
56 additional answers
    2011-02-04T21:26:45+00:00
    Any developments, Tamarw?  I'm in the exact same situation.  I once had it listing files before folders...but only in certain folders (My Documents, I believe).  I can't remember what I did to it to make it behave right.  I had planned on doing the same to other folders but got sidetracked with all the other Windows 7 shite.  I'm still having an intermittent issue with explorer refreshing the folder after a move/copy/delete etc.  In trying to fix that I reset all my folder stuff so now I'm stuck with folders above files.  WHO CODES THIS ____?!?!!?  HAVE THEY HEARD OF UAT?!?!?
    Rex
    2011-02-05T21:11:03+00:00
    I am unable to repro this issue, either in the files and folders view or in the file attachment window. The folder always sort to the top when I sort in reverse chrono order.  You haven't installed anything new lately?
    Rex, are you saying you have the exact same scenario troubling you, where you want to sort newest to oldest, but want folders to sort to the top?  Sorry for the ping, but doesn't sound like you have the same scenario in mind as @tamar...
