elliottme11 - it fixed issue - thanks for double posting - works - they need to make sure to check Programs (x86) <<<< aslo
How do I reinstall WLDCore.dll?
i continue to receive pop up error message WLDCore.dll was not found, reinstalling the application may fix the problem.
Windows for home | Other | Email and communications
2013-10-21T01:43:18+00:00 -
2013-10-23T18:26:37+00:00 I had same problem - tried this solution and it worked. Thanks
2013-10-31T07:09:22+00:00 Perfect! Thank you. Worked for Windows 8.1.
2013-11-04T10:15:53+00:00 I have this same problem but I still cannot "fix" it. I see you got it to work eventually. Any advice/explanation in simple, easy to follow steps!! Soooo frustrating!!! Message I get is WLDCore.dll is missing
2013-11-10T13:12:34+00:00 Thank you very much for sharing the information. I only wanted to make Live my default "mailto." After installing Windows Essential (only Mail and Writing). When asked to select a program for emailing to a link...@Live was there but the required .dll prevented default selection. Moving the files as you instructed solved the problem. Now when a link to email is selected, Microsoft Live is offered and I have all of the e.mailing options needed (automatically)
