Thank you!
How do I reinstall WLDCore.dll?
i continue to receive pop up error message WLDCore.dll was not found, reinstalling the application may fix the problem.
Windows for home | Other | Email and communications
2013-07-01T16:50:19+00:00 -
2013-07-24T17:22:46+00:00 Hi,
I had the same problem. Your solution probably works, but I was pretty sure I did not change anything to my installation. So I wondered why this file might have been gone astray. And then it hit me: I had been doing some cleaning up in my path settings. So I added C:\Program Files\Windows Live\Shared back to the system path, et voila...
You can find this setting in Control Panel > System and Security > System > Advanced System Settings > Environment Variables > System Variables > Path
Good Luck,
Weo
2013-07-25T16:59:13+00:00 Thanks you som mutch, that really worked:) Thanks Weo
2013-08-20T17:03:35+00:00 I'm not very much about PC computer technical works. Can I delete all the Essential items and then just install Windows Live Mail and expect it to work. I don't care for those Essential programs any way. I would just as soon as get rid of them. I have no plans to use any of them. The only reason I have them is because Windows Live Mail is in the package.
Would you please advise before I make an decision that I will regret.
Sonjia Starnes
2013-08-23T21:23:53+00:00 I had same issue. Here is how to fix it. This is easy and works! Thanks to whoever figured it out.
After long day of research, at last I got the solution. It seems the new Windows Live has grouped the wldcore.dll and wldlog.dll (used by Messenger, Contacts and Mail) to a folder c:\Program Files\Windows Live\Shared
Maybe because I did upgrade install it screwed up things.
The solution was simply copy paste those 2 files wldcore.dll and wldlog.dll from c:\Program Files\Windows Live\Shared to
- c:\Program Files\Windows Live\Messenger
- c:\Program Files\Windows Live\Contacts
- c:\Program Files\Windows Live\Mail
Now I can login to Windows Live Messenger and enjoy the whole Windows Live Essentials 2011 products.
You are an angel....a very smart angel. Thank you!!!!
Avtir
