How do I reinstall WLDCore.dll?
2011-03-29T18:02:46+00:00
i continue to receive pop up error message WLDCore.dll was not found, reinstalling the application may fix the problem.
Windows for home | Other | Email and communications
    2017-06-16T16:30:10+00:00
    Hallelujah. So easy with your instructions. I am 72 and a good amateur but there is no way I could have solved this error without your excellent pictorial instructions. Wish I could buy you a beer
    Alan Jones
    UK
    2017-06-28T20:01:50+00:00
    I have had the same problem and applied the same fix. It works. . . ONCE. Then the next time I try to email someone using an email address on a website, I get the same message that WLDCore.dll is missing. HOW DOES ONE PREVENT THE SYSTEM FROM DELETING THE FILES AT SOME LATER TIME? Is there a way to protect the files so NOTHING except the Administrator can delete them?
    BTW, it appears that the system only deletes WLDLog.dll; leaves the WLDCore.dll intact.
    2017-07-09T23:35:46+00:00
    I had same issue. Here is how to fix it. This is easy and works! Thanks to whoever figured it out.
    After long day of research, at last I got the solution. It seems the new Windows Live has grouped the wldcore.dll and wldlog.dll (used by Messenger, Contacts and Mail) to a folder c:\Program Files\Windows Live\Shared
    ![](http://blog.meidianto.com/wp-content/uploads/2010/10/image_thumb.png)
    Maybe because I did upgrade install it screwed up things.
    The solution was simply copy paste those 2 files wldcore.dll and wldlog.dll from c:\Program Files\Windows Live\Shared to
    • c:\Program Files\Windows Live\Messenger
    • c:\Program Files\Windows Live\Contacts
    • c:\Program Files\Windows Live\Mail
    Now I can login to Windows Live Messenger and enjoy the whole Windows Live Essentials 2011 products.
    How do I paste to the c\Program Files\Mail? Where do I find these programs?
    2017-07-10T10:09:29+00:00
    So easy to do. BIG THANKS. You make a good teacher, so well set out
    Alan Jones
  5. Deleted
