How do I reinstall WLDCore.dll?
2011-03-29T18:02:46+00:00
i continue to receive pop up error message WLDCore.dll was not found, reinstalling the application may fix the problem.
Windows for home | Other | Email and communications
    2014-03-21T23:24:04+00:00
    Maybe you or some program have changed the system environment variable PATH?
    I don't know the default value but it should work if you do a windows restore to a recent checkpoint.
    2014-04-13T13:53:45+00:00
    Grazie mille , sei stato utilissimo :)
    Ora windows live mail funziona benissimo
    2014-06-03T22:57:54+00:00
    Thanks  - worked for me!
    2014-07-30T13:45:06+00:00
    THANK YOU.  THANK YOU.  THANK YOU.
    I never ever would have figured this out on my own.
    2014-08-21T16:13:42+00:00
    I tried this - uninstall/reinstall.  I am still getting the error.  Any other suggestions?
