The issue damaged the MBR and that had to be rebuilt, not unexpected since the iastor.sys
is a hard disk driver.
No the same driver was in all the minidumps starting from that early one so it has not been updated.
You might have installed the same one again which was reasonable if there were no updated ones
available (no need now to re-install the same one).
You need to get the methods to install that driver from ASUStek and/or Intel - there is information
available at their sites and from their tech support. You need to know the procedure from them so
I will not guess though it probably is very simple, most are these days. Any time you are installing
BIOS or a low level driver (such as iastor.sys) a certain amount of care needs to be taken.
Hope this helps.
Rob Brown - Microsoft MVP <- profile - Windows Expert - Consumer : Bicycle - Mark Twain said it right.
