You can use Safe Mode as needed to troubleshoot - repeatedly tap F8 as you boot.
Check with ASUStek for updated Chipset drivers (get any BIOS updates while there). Then check
Intel Downloads for the chipset drivers.
iastor.sys = Intel Matrix Storage Manager driver - See your System maker (motherboard maker for
custom built systems) and the chipset maker. This driver could have been driven to fault by other
programs such as Symantec/Norton.
ASUStek Support
ASUStek Forums
http://vip.asus.com/forum/default.aspx?SLanguage=en-us
ASUStek Drivers
http://support.asus.com/download/download.aspx?SLanguage=en-us
Intel Downloads
http://downloadcenter.intel.com/
Intel Matrix Storage Manager - be sure to check for DATE and set for version of Windows and chipset
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22matrix+storage+manager%22
Hopefully the above solves the issue however if not here are more troubleshooting methods.
For BlueScreen troubleshooting methods using BlueScreenView and MyEventViewer see my replies
if this thread - top 3 answers (+1 other).
We can analyze the minidumps if you make them available from the SkyDrive or other file
sharing sites (such as MediaFire). If you have problems uploading the minidumps copy
them to the Desktop or the Documents folder and upload them from there.
Zip or upload the contents of C:\Windows\minidump
Use SkyDrive to upload collected files and post screen shot/picture.
BCCode: D1 0x000000D1Check these KB's
Stop error when you resume a computer that is running Windows 7 or Windows Server 2008 R2
from sleep or from hibernation: "STOP: 0x000000D1"
http://support.microsoft.com/kb/978982
Stop error on a Windows Server 2008 R2-based or Windows 7-based computer when the operating
system uses a virtual storport miniport driver to save a dump file or a hibernation file: "0x000000D1"
http://support.microsoft.com/kb/2320550
Those and 7 other KB Articles are available
Think Video drivers mainly though it can be others. See the driver section in my generic bluescreen
troubleshooting methods below. BIOS, low level chipset drivers and antivirus/antispyway/security
programs can also cause this. Check the troubleshooter and when you get to the driver and memory testing sections refer to the generic methods in next message and then return to the troubleshooter
if needed.
Cause
A driver tried to access an address that is pageable (or that is completely invalid) while the IRQL was too high.
This bug check is usually caused by drivers that have used improper addresses.
If the first parameter has the same value as the fourth parameter, and the third parameter indicates an execute operation, this bug check was likely caused by a driver that was trying to execute code when the code itself was paged out. Possible causes for the page fault include the following:
- The function was marked as pageable and was running at an elevated IRQL (which includes obtaining a lock).
- The function call was made to a function in another driver, and that driver was unloaded.
- The function was called by using a function pointer that was an invalid pointer.
BCCode: d1 0x000000d1 <-- read this linkhttp://www.faultwire.com/solutions-fatal\_error/DRIVER-IRQL-NOT-LESS-OR-EQUAL-0x000000D1-\*1210.html?order=votes
Look in the Event Viewer to see if anything is reported about those.
http://www.computerperformance.co.uk/vista/vista\_event\_viewer.htm
MyEventViewer - Free - a simple alternative to the standard event viewer of Windows.TIP - Options - Advanced Filter allows you to see a time frame instead of the whole file.
http://www.nirsoft.net/utils/my\_event\_viewer.html
Here are some methods to possibly fix the blue screen issue. If you could give the Blue Screen
info that would help. Such as the BCC and the other 4 entries on the lower left. And any other
error information such as STOP codes and info such as IRQL_NOT_LESS_OR_EQUAL or PAGE_FAULT_IN_NONPAGED_AREA and similar messages.
As examples :
BCCode: 116
BCP1: 87BC9510
BCP2: 8C013D80
BCP3: 00000000
BCP4: 00000002
or in this format :
Stop: 0x00000000 (oxoooooooo oxoooooooo oxooooooooo oxoooooooo)
tcpip.sys - Address 0x00000000 base at 0x000000000 DateStamp 0x000000000
This is an excellent tool for posting Blue Screen Error InformationBlueScreenView scans all your minidump files created during 'blue screen of death'crashes, and displays the information about all crashes in one table - Free
http://www.nirsoft.net/utils/blue\_screen\_view.html
Many BlueScreens are caused by old or corrupted drivers, especially video drivers however
there are other causes.
You can do these in Safe Mode if needed or from Command Prompt from Vista DVD or
Recovery Options if your system has that installed by the maker.
How to Boot to the System Recovery Options in Windows 7
http://www.sevenforums.com/tutorials/668-system-recovery-options.html
You can try a System Restore back to a point before the problem started if there is one.
How to Do a System Restore in Windows 7
http://www.sevenforums.com/tutorials/700-system-restore.html
Start - type this in Search Box -> COMMAND find at top and RIGHT CLICK - RUN AS ADMIN
Enter this at the prompt - sfc /scannow
How to Repair Windows 7 System Files with System File Checker
http://www.sevenforums.com/tutorials/1538-sfc-scannow-command-system-file-checker.html
How to analyze the log file entries that the Microsoft Windows Resource Checker (SFC.exe) program
generates in Windows Vista cbs.log (and Windows 7)
http://support.microsoft.com/kb/928228
The log might give you the answer if there was a corrupted driver. (Does not tell all the possible
driver issues).
Also run CheckDisk so we can rule out corruption as much as possible.
How to Run Check Disk at Startup in Windows 7
http://www.sevenforums.com/tutorials/433-disk-check.html
Often updating drivers will help, usually Video, Sound, Network Card (NIC), WiFi, 3rd party
keyboard and mouse, as well as other major device drivers.
Manually look at manufacturer's sites for drivers - and Device Maker's sites.
http://pcsupport.about.com/od/driverssupport/ht/driverdlmfgr.htm
Installing and updating drivers in 7 (updating drivers manually using the methods above is preferred
to ensure the latest drivers from System maker and Device makers are found)
http://www.sevenforums.com/tutorials/43216-installing-updating-drivers-7-a.html
How To Disable Automatic Driver Installation In Windows Vista - Drivers
http://technet.microsoft.com/en-us/library/cc730606(WS.10).aspx
How to fix BlueScreen (STOP) errors that cause Windows Vista to shut down or restart
unexpectedly
http://support.microsoft.com/kb/958233
Troubleshooting Vista Blue Screen, STOP Errors (and Windows 7)
http://www.chicagotech.net/vista/vistabluescreen.htm
Understanding and Decoding BSOD (blue screen of death) Messages
http://www.taranfx.com/blog/?p=692
Windows - Troubleshooting Blue Screen Errors
http://kb.wisc.edu/page.php?id=7033
In some cases this might be required.
StartUp Repair from Recovery Options or Windows 7 disk
How to Run a Startup Repair in Windows 7
http://www.sevenforums.com/tutorials/681-startup-repair.html
Download Windows 7 System Recovery Discs
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
How to Create a Windows 7 System Repair Disc
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
Hope this helps.
Rob Brown - Microsoft MVP <- profile - Windows Expert - Consumer : Bicycle - Mark Twain said it right.
