Eclipse CLD MP3 Player is not recognized. In Device Manager, I get the message that there is no driver installed.
2011-08-03T00:14:11+00:00
Original title: Eclipse CLD MP3 Player
I just tried to use Eclipse CLD MP3 Player and my computer doesn't recognize it.  I've tried the Troubleshooting steps and checked everything - In Device Manager, I get the message that there is no driver installed.  Is the player bad, or am I missing something?
2011-08-03T15:18:21+00:00
1. Were you able to use that player without any issue earlier?
2. Did you make any changes on the computer prior to this issue?
3. What exactly happen when you connect the player? Do you receive any error message?
4. Which troubleshooting steps did you try?
5. Did you try connecting it to different USB ports and check?
6. Did you connect it to different computer and check what happens?
Let’s try these steps and check.
1. Open the device manager.
2. Right-click on the device and select Uninstall.
3. Click on Action option in menu bar and select Scan for hardware changes.
41 additional answers
    2012-06-09T15:07:05+00:00
    Hi EDS Ellen,
    One thing you could try (no guarantee it will work), assuming you have Windows 7: when it looks for a driver, instead of having Windows search for one online, have it look on your computer and direct it to the \Windows\System32\DriverStore folder.
    After I had returned my Eclipse player I bought a Coby MP3 player and again ran into installation issues. After doing some searching online, I ran across the above solution and it worked (for the Coby). Don't know if it will work for the Eclipse but it may be worth trying!
    2012-06-22T00:31:08+00:00
    I really appreciate your taking the time to outline how to correct this situation. I had tried everything else. This worked! Thanks!
    2012-10-31T15:31:07+00:00
    I tried this, and the computer continued to tell me that it's not reading my player. I've also had my player turning on, but staying on the blue Eclipse screen. This player has worked fine for a long time, and I have no idea why it's acting up.
    2013-01-17T06:59:26+00:00
    worst mp3 ever, i wish i could go back in time i would slap myself for even thinking about getting this cheap **** 18 dollar failure of a music player. best buy needs to do themselves and everyone a favor and take eclipse off their shelves. also, whoever invented eclipse...SCREW YOU!!!
