Eclipse CLD MP3 Player is not recognized. In Device Manager, I get the message that there is no driver installed.
2011-08-03T00:14:11+00:00
Original title: Eclipse CLD MP3 Player
I just tried to use Eclipse CLD MP3 Player and my computer doesn't recognize it.  I've tried the Troubleshooting steps and checked everything - In Device Manager, I get the message that there is no driver installed.  Is the player bad, or am I missing something?
2011-08-03T15:18:21+00:00
1. Were you able to use that player without any issue earlier?
2. Did you make any changes on the computer prior to this issue?
3. What exactly happen when you connect the player? Do you receive any error message?
4. Which troubleshooting steps did you try?
5. Did you try connecting it to different USB ports and check?
6. Did you connect it to different computer and check what happens?
Let’s try these steps and check.
1. Open the device manager.
2. Right-click on the device and select Uninstall.
3. Click on Action option in menu bar and select Scan for hardware changes.
41 additional answers
    2012-03-17T05:04:52+00:00
    I have the same MP3 player, new out of the box, and it will not install under Windows 7. I've uninstalled and reinstalled the driver numerous times without success. I've run the troubleshooter also without success. Below is the report that the troubleshooter generated. Hopefully someone has an answer!
    Devices and Printers Publisher details
    Issues found
    DTMB BDA TV USB has a driver problemDTMB BDA TV USB has a driver problem
    There is a problem with the driver for DTMB BDA TV USB. The driver needs to be reinstalled. Not fixed
    Reinstall device driver Completed
    Problem with PnP devicesProblem with PnP devices
    There are problems with some PnP devices. Windows will take additional steps to further troubleshoot these devices. Detected
    Potential issues that were checked
    Windows Update configured to never install driversWindows Update configured to never install drivers
    Driver updates aren't automatically installed when detected by Windows Update. Issue not present
    Issues found Detection details
    6 DTMB BDA TV USB has a driver problem Not fixed
    Device information
    Name: DTMB BDA TV USB
    Error code: 10
    There is a problem with the driver for DTMB BDA TV USB. Reinstalling the driver might fix this problem.
     Problem with PnP devices Detected
    Potential issues that were checked Detection details
     Windows Update configured to never install drivers Issue not present
    Detection details
    Collection information
    Computer Name:  XXXX-PC
    Windows Version: 6.1
    Architecture: amd64
    Time: Saturday, March 17, 2012 1:00:57 AM
    Publisher details
    Troubleshoot problems with devices and printers.
    Package Version: 2.0
    Publisher: Microsoft Corporation
    Hardware and Devices
    Use hardware and access devices connected to your computer.
    Package Version: 1.1
    Publisher: Microsoft Windows
    Windows Network Diagnostics
    Detects problems with network connectivity.
    Package Version: 1.0
    Printer
    Troubleshoot problems preventing printing from completing.
    USB
    Troubleshoot problems with a USB device
