Drag and Drop confirmation prompt? Accidentally moving files.
2011-03-25T15:44:05+00:00
Ever since upgrading to Windows 7, we have had a problem with people inadvertently moving folders by dragging and dropping when meaning to double click.  Is there a way to turn on a confirmation prompt ("are you sure you want to...") when dragging and dropping files/folders?  It seems that previous versions of Windows had this prompt, but it has since been removed.  This is happening in our office on at least a weekly basis, sometimes daily, and we have to spend time searching for the moved folder.  If MS is unable to help, is there software that we can purchase to accomplish this?
@CmdrKeene 90,631 Reputation points Volunteer Moderator
2011-03-25T16:29:55+00:00
Windows 7 made no changes: there has never been a confirmation prompt like you describe.
One workaround is to increase the distance you must move the pointer before it triggers a drag.  Under the following registry key, you'll see DragHeight and DragWidth, which define the number of pixels the mouse must move before the drag is initiated:
Computer\HKEY_CURRENT\USER\Control Panel\Desktop
63 additional answers
    2015-10-24T16:55:42+00:00
    The mouse settings windows were not quite as described in this post, but I still found a an option to "Turn on ClickLock." after doing so, in Win7 (with all updates through October 2015), moving a file now requires two clicks, one to designate the file to be moved and one to confirm the drop location.  It also forces one to make additional "clicks" on other windows operations, but I'm not yet clear as to how an when.
    I think it is a small price to pay for reducing the number of wrongly moved directories.
    2015-11-12T12:13:59+00:00
    So I found this app...! Just install and its working right after.
    Hope it fit your needs!
    Why MS Is not listening us?
    http://broken-e.com/dragdropconfirm/
    2016-01-04T01:25:43+00:00
    that is your problem, searching on Bing...
    2016-01-20T16:27:52+00:00
    FYI DiasAlessandro, that app has already been discussed... see previous posts on this thread.  broken-e wrote that app to help people on this thread.
    THANK YOU broken-e!  you have saved many bits of data that would have otherwise disappeared!
